Ouch. Scary, I'm running my 930 on Castrol GTX - and it only does hard track time.
What oil should we be using to avoid this? I wont have as many options as you guys, so some big brand names would be good. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
I'll be making the switch to full synthetic, gonna have to do a little investigation... have a look here. There's a couple other threads out there, the discussion is debated with passion on the turbo forum. This will get you sttarted!
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils What oil to use in a 930?
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud |
