Exhaust Studs-Block Use Loctite/Antiseize ?
I have all my exhaust studs out.
Should I use any thing on the threads on the studs going into the block. I will be using anti-seize on the threads that stick out of the block. |
going into the block..youre changing the dilivars out
The studs will seat to the bottom, I usually clean the hole and put them in dry and tight. I could see using blue loctite, not red. I like to grease the threads before I install the heads so I can get a good torque moment. Bruce |
Good Ole Boy
dm
1977 911S 2.7 Sunroof Coupe (My Midyear Crisis) ![]() 1998 Honda Shadow ACE 1100 1990 "Redneck Porsche" 5spd, 7.5 litre efi 4x4 Regular Cab F-250 |
Yes, you are right it is the heads, but since everything is all together as a Long Block I faux paux'ed
Good Ole Boy
I'm probably two months from the long block stage, still waiting on and ordering parts. Enjoy! dm
For the exhaust studs ... just use anti-seize on the exhaust nuts (or thread of the stud).
I was told NOT to use anti-seize on the threads going into the heads b/c you don't want the studs to come out while trying to remove the exhaust nuts in the future. When I tore my engine down half of the studs came out with the nuts. I also used loctite on the thread going into the heads. Not sure if this is needed though.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
