CMDR Perry's Avatar
E-clips for piston pins?
Has anyone tried using an e-clip for piston pin retention in place of the circlips?
Old 08-27-2009, 03:26 PM
Not tried it...but why risk it ? The consequences may be severe !!!
The circlips are designed for the job, and I doubt they are the critical line in the budget.
Old 08-27-2009, 03:42 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you are looking for the ultimate retention of wrist pins...I think Spiral-locks are probable the best.
Be advised...they are a total b**ch to install....which probably means they are the hardest to get back out....either by you or the engine.
I have used them is many engines...and never had a failure.
I have seen Nitro burning engines disintegrate and still have the locks in the remains of the pistons...even though the pistons were in several pieces.
Bob
Bob Hutson
Old 08-27-2009, 05:23 PM
CMDR Perry's Avatar
e-clips
Thanks, I was just curious since they are such a pain to remove and install.
Old 08-27-2009, 06:13 PM
smokintr6's Avatar
Send a message via AIM to smokintr6
There are some tools available that make the install the easiest step of engine rebuilding. My guess is our host sells them, as well. There was a guy with a demonstration display setup at hershey this year. They are not overly cheap, but IMO if you are not comfortable installing the clips it's probably worth it. Whatever you do, seal up all the openings to the crankcase while you are messing with piston install... You don't want to have to strip the case to find missing pieces, and those suckers can FLY if they get rejected.
Old 08-28-2009, 08:27 AM
