Update -- Cylinders and Pistons Off
Sierra Hotel. I finally got back to work on her today. Cylinders and Pistons came off without any problems. I'm still trying to solve the mystery of what these parts are though. Some pictures posted below.
Troublesome oil line still attached although I purchased some good wrenches this weekend so maybe it'll come off yet. -------------------------------------------------------------------- http://forums.pelicanparts.com/uploa...1255317823.jpg All the pistons had "83 95" stamped on top of them. The number 1 piston had "Mahle 84P11+" stamped underneath. http://forums.pelicanparts.com/uploa...1255318233.jpg |
One more question;
How do you know if the head studs have been updated to the "case-saver" type? I don't have any pictures yet but will post if that helps. L |
Found the piston cross reference post so now I know what the pistons are:
http://forums.pelicanparts.com/porsche-911-technical-forum/364817-2-2l-vs-2-4l-s-pistons-how-id.html |
Landon,
The case savers refer to threaded inserts in the case that the studs thread into and not the studs themslves. If you remeber, I pointed these out on my case when you visited. Since you are taking your case down this far you should send it out and have this modification(among others) installed. Enjoy. Dana |
Oil Lines ar a Mike Foxtrot to get off.
I used two Big ass wrenches, with cheater pipes over each one. With an extra 2 ft of leverage on each wrench end, they break loose. But I couldn't get anywhere without the cheater pipes. Richard |
Landon |
Case Seperation
Update -- I got the case separated today and that darn oil line finally came off.
The case came apart pretty easily once I re-read Wayne's book and got the gouge on how to do it. The hardest part was getting the flywheel off. I found the triple-square bit (12mm -- aka "serrated wrench" at Napa Auto parts) to perform the op but it was so long that the engine stand yoke interfered with the breaker bar. I eventually just forced it in to place so that the bit would be square with the bolts and was able to crack them loose. Will have to do something different for the re-install, like maybe buy the triple-square in socket form. It took me about 15 minutes of tapping to get the case halves apart. There was one hitch though; I turned the engine right-side-down (with a safety bolt installed to hold the lower half of course) and while I was tapping it apart, a mystery part fell out: http://forums.pelicanparts.com/uploa...1255830021.jpg Once the case came apart, I couldn't tell where this may have come from. It was near the front of the engine more-so than the back part -- like near the oil pump maybe. Anyway, its bagged up for later identification. I'm still trying to figure out if I need to pull the head studs out. None of them are pulled out any and externally, they look fine. Anyone got any suggestions? I know the stock answer is "while your down there, might as well..." but somebody previously had the engine apart and I'm wondering if there's a way to tell if these studs are in good shape. They are all magnetic. Here's the photo. Note that this is not my bike in the background. http://forums.pelicanparts.com/uploa...1255830820.jpg |
Landon,
Oil pressure relief valve. Hang onto it unless you modify your case.....hint,hint,hint. Then you would want a differant type. |
Why would one modify their case? Mine are 4R's but I couldn't find anything coherent on what that means or doesn't mean. BTW, got the crank out today but it certainly didn't lift out "with minimal effort" like the book said. Guess I need to start looking for a good machine shop. Where was that one you were telling me about? |
You will want the Porsche machine shop to perform the standard improvement to your mag case.
This will include as a minimum: 1. Time certs 2. Oil bypass modification (Dana's hint) 3. Line bore check and correct |
Landon,
Sent you a PM. Are you sure that's not your bike? Dana |
+ 1 on what Tom says.
Also, for the flywheel bolts you can use an open endded wrench with your tool to get them off. When re-assy. just get one or 2 of them tight in the same way and then when the engine is off the stand and the engine mount is off you can use your flywheel lock and torque them all down properly... Just DON'T forget!! I use a paint pen to mark every nut/bolt that I tightened so I would not miss one or do one twice. I used white as yellow and red seem to be used by others a lot on my engine. Enjoy! -Michael P.S. Sure looks like your bike ;) |
I guess I need to post a picture of my bike. |
What's next?
Thanks all for the help. As a noob, I need to be hit upon the skull with suggestions...
Anyway, understood on all the standard mag case improvements. What should I do with the heads? I haven't touched them since taking them off. I'm guessing there's machine work involved. Is it better just to leave them assembled or can I save myself some $$ by doing it myself? Any mods I need to worry about with these? How about the clutch? Seemed to work fine before. L |
Heads you need to send out. Its possible to do them yourself, but the procedure is quite involved and then that is just the guide replacement. To deck them requires a mill and machining expertise to get them all correct.
my advice is send them out... ~$600-1200 depending on who and what you have done. there are several good shops you may use. -michael |
Landon,
I am curious as to what your costs will be. I am looking at a 1973 911E 2.4L engine and a 1971 911E 2.2L engine. The first is in good running condition, and the second needs a complete rebuild. I was trying to find a ballpark cost of a DIY rebuild (including the specialty tools). So far: I sourced Pelican for parts ($2500). Machine shop ($1800). I am using a slightly used Carrera oil pump ($500) and flywheel ($150). The engine is $1600. Total (so far)= $6550. Good luck on your project, Doc |
Doc,
You've already given more thought to the cost of your rebuild than I have. So far, I've just been plugging along and haven't thought about the cost. Probably not the best plan. Your estimates seem reasonable though. The machine shop costs look close to what I'm figuring and I'm also thinking of the upgraded, pressure-fed tensioners. I hadn't really thought about the oil pump upgrade but it would be much easier to do now. My pump is stock and looks to be in good working order now. I haven't calculated what all the parts will cost but your figure looks higher than I plan on spending. I've bought a couple of specialty tools that I don't plan on keeping after I'm done. Keep an eye on the used parts forum in 6-9 months as I'll be selling these. If you have Wayne's book, there's some good estimate tables in there. It's kind of depressing to read as my budget doesn't match my plans. I'm blissfully ignorant of what's ahead. Sorry to not be of more help. I have been saving all my receipts to see how much I spend in the end and will post that for others. Good luck to you and how about a picture? Landon |
I do have Wayne's book, but I forgot about the tables. The car came with a mismatched set of Fuchs wheels (16" and 15", go figure). So, I found 3 other proper 15" wheels and will restore all 5 (one real spare) with the DIY threads about wheel painting and restoration (the budget way). I can't find a picture of the Bahia Red '71 but the body is nice with all new suspension and brakes. It needs seats. My absolute total budget is $20K, and that includes some nice seats. Here's my only longhood that is moving on it's own power ;): http://i27.photobucket.com/albums/c1...braR/73RSt.jpg |
Any updates?
Hello Dana. I was just getting ready to PM you but I'll provide an update.
Everything is apart and looks to be in good order. My Mark-I eyeball shows the crank to be OK as are the rods. The rod bolts were pretty hard to get off as the clearance between them and the rod were awfully small to get a socket on. When I was inspecting the case, I noticed some damage from where one of the chains had evidently slipped and gouged up the case. It's mainly some scrapping of the magnesium but I'm not sure if it's superficial or serious damage. It looks to me like a machine shop could mill out the damage without affecting the structural properties the case -- i.e. the gouges aren't too deep. This did not happen while I was driving it so it's previous damage. I'm most worried about the scarring and the areas shedding some metal shavings so I'll ask the shop if they can fix it. Speaking of that, I called Ollie's last week and talked to Ike. (BTW, they have a different phone number -- (928) 855-6101 but they still answer the (714) number.) Will probably ship everything off this week if I get time. Question: What do I need to do to the case before sending it? Remove the head studs? Remove the case studs? All of them are magnetic so I'm pretty sure no Dilavar. I already know to get the case-savers installed. Since I'm getting ready for some down time on the engine, I've been taking apart the interior/doors to see what I need. I was also shopping for an upgraded oil pump... How hard is to add an external oil cooler? That's about it. I'm just staring at all the parts and reading ahead on how to put it all back together. The tear-down was a breeze compared to what I'm about to get into with re-assembly. Landon p.s. Can you PM me your address so I can ship the gear-puller back to you? |
| All times are GMT -8. The time now is 08:22 AM. |
