-   -   The Dude's Rebuild; 72 911T (http://forums.pelicanparts.com/911-engine-rebuilding-forum/498738-dudes-rebuild-72-911t.html)
The Dude 05-07-2010 07:41 PM
Wilco on posting some pictures. Anything in particular you want to see (any special part of the case)?
bavaria911 05-07-2010 07:47 PM
My case is at Ollies right now. How about send pic's of detailed outside and inside of the case, basically all modifications.
TIA,
The Dude 05-08-2010 09:48 PM
post-Ollie's pictures
OK, here's what I have for post-Ollie's pictures.
First, this is before-and-after on a piston (they still look like S pistons to me):
http://forums.pelicanparts.com/uploa...1273379410.jpg
http://forums.pelicanparts.com/uploa...1273379494.jpg
Here's a head and cam tower after shot:
http://forums.pelicanparts.com/uploa...1273379641.jpg
http://forums.pelicanparts.com/uploa...1273379748.jpg
Finally, a shot of the case where you can partially see the bypass mod. I also had them align bore to std, new inserts all around, clean the squirters which I'm doubting I can get a good picture of.
http://forums.pelicanparts.com/uploa...1273379884.jpg
What else? For the most part, I have everything packaged up for my move next month and I'll be on hold for the assembly until at least July. As I said previously, Ollie's gave me 10%+ off the price because I paid cash and picked it up myself. I will say that they did a fine job packaging everything up.
-Landon
The Dude 05-08-2010 09:59 PM
One more thing; I can dig something out of the box if there's a picture someone wants to see that I missed. Let me know.
L
The Dude 05-17-2010 07:08 PM
Signing off temporarily
Alright guys,
I'm going off-net for a while so we can move to SoCal. Should be back up later this summer. Can't wait to get back at it.
Landon
ddinham 05-17-2010 07:34 PM
Good Luck Buddy.
The Dude 09-06-2010 08:56 PM
Back on-line...
...in the high desert of California.
Just pulled the car out of storage and into my own garage. started dusting off my rebuild books trying to remember what I still need.
Landon
ddinham 09-06-2010 08:59 PM
Glad to see you are back in the saddle.
The Dude 09-06-2010 09:55 PM
not quite in the saddle...more like looking at the saddle and a reluctant horse.
The Dude 09-19-2010 10:54 PM
Engine hardware shopping in Anaheim
I'm going to be in Anaheim, CA for a couple of days. Would like to pick up some of the missing pieces I need to start the engine rebuild. Anyone know of any good stores in the area? Specifically, I need (from Wayne's book)
- some of the sealants
- rod bearings
- rod bolts
- flywheel bolts
- main/intermediate bearings
- engine case hardware
- all the little parts you have to replace when rebuilding
Anyone heard of Westwerk? Looks like it might be close.
Thanks.
Landon
ratpiper71T 10-16-2010 11:18 AM
Bump for progress?
The Dude 10-17-2010 06:07 PM
Glad you asked...
Just got done putting the first rod on the crank. Gotta admit I was scared to start, but after staring at everything for a couple of days, I thought I'd just jump in. All the stuff from Pelican came in about 2 weeks ago so I didn't have an excuse not to get going. I felt like a surgeon putting this thing on.
After one rod install, I realize I still need more patience.
http://forums.pelicanparts.com/uploa...1287363780.jpg
chiroracer 10-19-2010 10:52 AM
Good man! I am getting ready to do a similar build. Steve in SoCal
The Dude 10-19-2010 09:45 PM
So now I'm wondering how free should this thing turn (the rod, that is). It spins OK and it will fall under its own weight. Anyway, one down and five to go.
L
ratpiper71T 10-20-2010 07:12 AM
So now I'm wondering how free should this thing turn (the rod, that is). It spins OK and it will fall under its own weight. Anyway, one down and five to go.<br>
<br>
L
This seems to fall in line with Waynes book (you do have it , right?) he seems to stress that they all fall under their same weight but at THE SAME SPEED as more important. Did you do the plastigage test?
The Dude 01-17-2011 08:29 PM
Crank complete!!!
Man, that took me forever. Got derailed because I might have to move again this summer. Anyway, they all fall under their own weight at roughly the same speed except one of the early ones I put on falls a little faster.
Next up the case. Ouch. That's a big step. So I'm looking at the P201 yoke and how to mount it on the right case half. Ollie's put new inserts in so the studs aren't there...yet.
Anyone have any gouge on how to put the studs back in?
Landon
chiroracer 01-21-2011 03:45 PM
just measure the boss on the trans where it goes through and add enough more for the nut and two threads. press on boldly! Steve
The Dude 01-21-2011 10:22 PM
Thanks Steve.
Just did a forum search for installing studs.
Do the tranny studs go in finger tight?
Should I use locktite (red?)?
use the dual bolt method?
Safe to use the old ones or should I buy new ones?
Forum's useful but I didn't find all the answers.
L
The Dude 01-29-2011 08:54 PM
bump
mcaterino 01-30-2011 05:44 AM
Landon,
I won't say these are the right answers, but this is what I did. The new inserts were deeper than necessary. I sunk 1cm in the case, using red loctite, and didn't need to use any nutting or anything else to drive them in. As I saw it you just needed them in the thread deep enough to hold on. The torque comes from the nuts on the trans side. I didn't have any old studs, so bought new. But I wouldn't have hesitated to reuse them if I had them. Those are pretty tough studs.
Mike
