aadrew10's Avatar
Opinion on using case sealant between head and top of cylinder
Hi,
I have 98mm nikasil pistons and cylinders. They cylinders do not use a head gasket. I would like to know any thoughts on using a small amount of case sealant on the head just like what is used for the cylinder base gasket, as well as your reasoning.
Thanks,
- Andrew
Old 10-01-2009, 11:11 AM
The cylinders are Carrera so you need to torque to 15ft# then go back again, hit 15 and then 90 degrees with the torque wrench
There is a bevil on the Carrera cylinders where they meet the heads and youre torqueing to the Carrera spec.
Bruce
Old 10-01-2009, 11:31 AM
I wouldn't use sealant here. It hardens and then will crack when the heads heat up and cool down. It might not hurt but I wouldn't take the chance.
-Andy
Old 10-01-2009, 01:50 PM
3.4 Bigger is better
88-diamondblue's Avatar
+1 with Eagledriver
The surfaces were designed to seal by just contact and pressure.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 10-01-2009, 04:28 PM
