-   -   My case does not want to separate (http://forums.pelicanparts.com/911-engine-rebuilding-forum/500832-my-case-does-not-want-separate.html)
jwasbury 09-22-2009 07:24 PM
Doing a rebuild on my '79 930:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/492267-jacobs-rebuild-thread.html
I'm down to the 'fun part' trying to separate the case halves. In the 'Case Separation' section of Wayne's book, it says "the case should immediately begin to separate" upon tapping with a mallet. Well, that is not what's happening for me. Towards the bell housing end, I think the parting line is separating just a bit...about the width of a mosquito's pecker. On the front side of the engine, I see no evidence of success. The book also uses the term "tapping." Since tapping was not yielding any result, I've tried some whaling as well. Still no go.
I've double and triple checked that all fasteners have been removed. Counted 22 13mm nuts (correct amount per the book), 11 through bolts, 2 15mm nuts under the oil cooler and the super-secret nut inside the chain housing.
I have a couple of theories:
1) Separating case halves is not as easy as it sounds in the book.
2) I need a bigger BFH, like a RBFH
3) Case has been apart before and was re-sealed with some ultra strong 3M adhesive like what dentists use to bond crowns to teeth.
Any ideas folks? I am afraid to continue beating on the case unless I hear that this is not unusual.
dtw 09-22-2009 08:32 PM
Hang it up for the night. Wash up, go to bed. Come back tomorrow.
Ok, you're back? Go around the case and make sure you removed all the aluminum crush washers. They can do an amazing job of hanging up on the studs when they have been over-tightened.
Now, go around the perimeter with your hands and eyes, looking for remaining/forgotten nuts. Forget the nut count. Nuts under the fan strap area? By the breather orifice? Under the flywheel? Bottom of case, nuts facing oppositie direction than rest of nuts? "Death nut" that secures the intermediate shaft bearing saddle (not on perimeter...sorta out in space by itself)?
You already mentioned the chain housing nut and the cooler nuts, guess you're good there.
If you really got all the fasteners, get a length of soft wood and use it as a drift. Plenty of flanges and meaty areas on the case to use it on. Give your hammer good smart raps against the wood. Move around the case in a circle, so you don't get one side cocked up and frozen.
Flat6pac 09-23-2009 05:17 AM
how about the 10mm inside the left chain area inside the case..It has to be a fastener somewhere..behind the oil cooler?
Should just tap apart
Bruce
jwasbury 09-23-2009 08:14 AM
Bruce
That's the "super secret" nut I mentioned. Removed from inside the case where the chain runs. It was an M10 17mm nut in my case. Both 15mm acorn nuts removed from the oil cooler area. Before I posted last night, I went back to the garage and quadruple checked with the book in my hand and verified each of the nuts in the photo had been removed on my case. Is there some 'bonus nut' that isn't in the book? Anything specific to a turbo case that isn't included in the book?
CliffBrown 09-23-2009 09:07 AM
Make sure to also remove all the washers. They can make separation difficult.
Use a BFH and use it lightly front and back.
colescrogham 09-23-2009 09:40 AM
Case
2 things I regularly forget: the 2 bolts with nuts (not studs) that have the nuts actually going the other direction than the studs on the bottom at each end of the later cases, and the cover for the intermediate shaft that must be removed before the case can be split in earlier ones.
Another great one to forget is the nut for the long stud by the oil pump. Its located in an odd place on the left side not on the perimeter. They tend to leak and have seen a few almost disappear with a lump of crud over the years.
I don't think the case halves are going to leap apart, but you should be able to get some separation without whaling...
jwasbury 09-23-2009 10:18 AM
I'm pretty sure I got all the sneaky nuts on the back side and the one for the oil pump (it's towards the bottom, underneath the cylinders but not on the perimeter).
I will go back and quintuple check that all nuts are removed.
I did have some stuck washers. Started the attempted separation with them in place, and then figured that they could be hanging things up, so I removed them with pliers. Will check again for stragglers.
We'll have another go at it tonight.
Jesset100 09-23-2009 12:46 PM
Intermediate Shaft End Cover
sand_man 09-23-2009 03:54 PM
As we discussed by phone, earlier:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/167040-case-splitting-tool.html
Obviously make sure all of the required hardware has been removed....
jwasbury 09-23-2009 05:28 PM
Thanks for the link Jeff.
After a stimulating day at the office, a good deal of which was spent obsessing over my rebuild project, I took another crack at this case...literally.
I would love to tell you all how I found a fastener (or intermediate shaft cover) that I previously overlooked and post a nice photo of my crank and oil pump, but I can't.
After checking to insure I've removed all the necessary hardware another 12-15 times, I began beating on the case with my mallet for another half hour...
Looks like my case may be 'special'
That case splitting tool looks like it might be the ticket. I'm intrigued by Henry of Supertec's method, although I don't quite understand the detail and how its supposed to work.
jwasbury 09-23-2009 05:42 PM
I should add a few data points to this thread. I am a lightweight at about 140lbs. This is my BFH
http://forums.pelicanparts.com/uploa...1253752734.jpg
Perhaps my concept of beating on the case is not enough force? Maybe I need a bigger hammer, or maybe I should put on some weight?
CliffBrown 09-23-2009 05:44 PM
Show us where you're hitting the case.
jwasbury 09-23-2009 06:18 PM
I've done the "4 corners" per Wayne's book. I've also hit it around the entire perimeter of the parting line in an effort to break the seal, even though the force of the blow was not in the direction of separating the halves.
JFairman 09-23-2009 06:34 PM
sounds as if someone used JB weld as a case sealant on it.
jwasbury 09-23-2009 06:43 PM
My worst fear:eek:
CliffBrown 09-23-2009 06:49 PM
Put the acorn nuts back on the studs under the oil cooler and the nut back on the stud under the driver's side chain case.
Try hitting the acorn nuts and the front stud (nut) with your hammer alternately. Use an old socket extension or brass drift to reach the front stud.
TibetanT 09-23-2009 09:43 PM
Subscribing...
bpu699 09-24-2009 10:29 AM
Just a thought...
If its been sealed, or glued, or JB welded... then a propane torch should seperate it...
Even JB weld fails at 600 degrees or so, right?
jwasbury 09-24-2009 11:43 AM
So it says on their website...I checked it.
I've got a plan for a splitting tool similar to what was done in the 'case splitting tool' thread link posted above. I just can't take this prehistoric $hit any longer:
http://forums.pelicanparts.com/uploa...1253817634.jpg
I'll also have my propane torch handy...stay tuned.
Fast Corners 09-24-2009 12:17 PM
Wow, that is just too damn funny!
jwasbury 09-24-2009 07:03 PM
update - some successful progress
I made myself a case splitting tool using a craftsman gear puller I already had and some pieces of scrap metal.
http://asbury.smugmug.com/photos/660000824_AY89A-L.jpg
I put some torque on it and left it to sit for a minute or two when I heard a loud CRACK! It was the sound of the seal busting open (finally). The sealant is really bonding these case halves together. At least I have the top side parted:
http://asbury.smugmug.com/photos/660001148_r94GA-L.jpg
The bottom side is still sticking fast. Got out the hammer and started beating again, but I did not have much time to work at it this evening. Have a look at the sealant in this picture. I'm guessing that this is not factory?
http://asbury.smugmug.com/photos/660001547_CVUGY-L.jpg
davidbir 09-24-2009 07:08 PM
It looks like Permatex Aviation sealer but I have never seen it stick like that before!
JFairman 09-24-2009 08:20 PM
uh oh.. the grey stuff does look like epoxy...
If it's soft it's silicone.
all the "aviation #2 non hardening" gasket sealer I've used is reddish brown and it does pretty much harden after time and heat cycles.
jwasbury 09-25-2009 06:13 AM
Most defintely not silicone. The stuff is hard as a rock. It could be this aviation sealer you speak of...the color does appear to be reddish brown, especially where you can see it inside the case (such as under the breather cover).
sand_man 09-25-2009 07:15 AM
So did you have any idea that your case had ever been apart, before?
jwasbury 09-25-2009 07:53 AM
Nope.
Based on info I have, my car has been through 5 owners before me. I spoke with the second owner who had the car the longest (from about '81 - '00, nearly 20 years.) I specifically asked if any major work was done, and was told no. He is a wealthy guy (CEO of Chaparral boats) but I can't imagine he would forget writing the check for a full rebuild. I also spoke to the guy who bought it from him (3rd owner from '00-'03) who too said nothing major was done. I have invoices from this period of the car's life forward. Unless these people are lying (and why would they when they are several owners removed from my purchase) or are forgetful, it suggests that the engine was rebuilt within the 1st couple years. Strange.
BK911 09-25-2009 10:04 AM
I use a small turn buckle on the studs on front of the engine, and another on the studs in back of the engine. About $3 at home depot. Good luck!
jwasbury 09-26-2009 05:43 PM
success at last
The case is apart!
I made a second splitting tool to get the bottom side cracked open. Just like the topside, I put some tension on this and waited for a minute before the SNAP! of the sealant breaking loose.
http://asbury.smugmug.com/photos/661703244_zohJR-L.jpg
Here's the obligatory pic of the crank and oil pump. I found some of the hardened sealant on the intermediate shaft gear...whatever that stuff is, its tenacious.
http://asbury.smugmug.com/photos/661..._gerrt-L-1.jpg
Now back to your regularly scheduled rebuild...
torresmd 09-27-2009 09:10 AM
Great job! Keep up the good work.
