case splitting tool
After using the rubber mallet method to split the cases with no luck I decided to build a tool to do it. I removed the two studs on the top of the case that have a section of case between them on one side but not on the other. I made a plate to bolt on the back side of the two stud holes with a jack bolt in the middle. I used an aluminum softening plate under the jack bolt. After getting a little seperation, I used a rubber mallet to split them the rest of the way.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Dave:
Looks like you and I are on the same track. Which EFI system are you going with? My rebuild progress Brian
Brian Keith Smith |
Author of "101 Projects"
Neat idea. Good for those shuffle-pinned cases...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Friend of Warren
Great idea! That hardest part of my 3.2 rebuild was getting the damn case to split!
Kurt V No more Porsches, but a revolving number of motorcycles. |
Try not, Do or Do not
Can't teach an old dog new tricks, unless the trick makes sense.
I like to tool but I don't see a need for it.
A good sharp blow to the yoke on your disassembly stand and the case halves jump apart. No beating, no prying. The engine is already in the stand so the only additional work is to swing the hammer. For those of you who take a great deal of pride in your one and only engine stand, be warned ! "This method is hazardous to your stands appearance". That's why all of our engines come apart on the same stand.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 06-10-2004 at 07:42 AM.. |
This being my first time to split a P-car case, I was a little leary about hitting it too hard.
As for the EFI, I'm strongly leaning toward Autronics, but the decision hasn't been made yet. My reasons are: quality, sequential injection, ignition, I've heard good things about it, and it's significantly cheaper than the M600 Motec system.
There are a few other ways of separating the case, but if you do it wrong, you can damage the case. That is why I didn't put them in the book...
-Wayne
