Tim K's Avatar
Looking for spark plug wire bits (wire, boots, etc.)
I'm looking for brands/suppliers of plug wire components (wire, boots, etc.). I've searched here and on the web and I'm not having any luck. Any help is appreciated.
Tim K
Old 10-13-2009, 09:56 AM
MSD sells high quality low resistance 8.5mm spiral core wire, connectors, and kits with all the stuff including a connector crimper tool you use in a bench vise you need to make your own wire set.
at least they used too...
Old 10-13-2009, 10:02 AM
NAPA has it for some applications...custom wires..
Bruce
Old 10-13-2009, 12:58 PM
Doc Speed
Neil '67 911S's Avatar
Is there any particular reason to go with special ignition wire when using a Delta Mark 10b CD ignition box? Or will the stock, copper wires do?
Thanks!
- Neil
'67 911S (Ol' Ivory)
'82 Hewlett Packard 34C
Old 10-15-2009, 06:12 PM
Tim K's Avatar
Thanks guys.
Tim K
Old 10-15-2009, 07:27 PM
