Looking for info on what port size and valve size to go with for a 2.8L build (long stroke). Going to be using 2.7L heads (from a 74' no smog ports).
Also looking to go twin plug with these cylinder heads. Engine will be used for a street car (914-6). Thanks in advance! Dominic |
What cams will you be running??
Head specifications depends on RPM range and required airflow therefore camshaft profile determines what head configuration you need.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Steve,
I would like some advice on the Cam as well. I would love to build an engine with a broad torque band. I don't want an "S" profile with all of the HP/torque at 7000rpm, looking for something with a usable band of torque for a fast street car. Thanks for your help! Dominic |
I'd recommend a Solex cam for a good 2.8 but be careful about compression ratio if you need to run on pump gas. Stock 2.7 heads, suitable modified for the 92mm P/C's, will serve you very well.
