911 Eng cost for rebuild or replacement
Looking for a 911 LWB "S". If I find a project (I prefer to do an int. and paint anyway)
what am I facing for a rebuild cost wise for:
1. Full rebuild on tired worn out eng.
2. Replacement eng in case of catastrophic failure.
Just inquiring for standard HP "S" class eng.
Old 10-28-2009, 10:01 PM
Crusty Conservative
silverc4s's Avatar
I did a 2.2 S rebuild that was truly worn out about 10 years back. Used the original cases, crank, rods, 5 heads, 1 cam tower. All else was replaced with new or rebuilt to new specs. Cost was over 20 large, including SSI's and a few other niceties - but almost completely factory parts.
Probably cost you a bit more today, as all the MFI parts & labor costs are up, and S P&Cyl are unobtainuim for the most part.
Good luck to you - don't go in to make a profit, do it because you want it for yourself.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 11-15-2009, 01:24 PM
304065's Avatar
A 2,2S is one of the most fun engines Porsche ever made. I would stand by the $20K number to do it RIGHT. Search here for "901/05" for my engine rebuild project- that's about 10K in parts and miscellaneous stuff, my labor is . . . free?
But you are asking the right questions up front and WELCOME to the forum.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-15-2009, 02:05 PM
Wow. After many years of newer P car ownerships and several dozen cars, I'm surprised it its this much. I guess after all these years I've just never been faced with a teardown. I'll look for a car that doesn't have eng. issues. Interiors and paint are starting to look real inexpensive.. Thanks for your input.
R
Old 11-15-2009, 02:45 PM
911 tweaks's Avatar
all the above very accurate info...
nice paint will run $10k easily...this is to strip the car, fix any small metal issues, prime & paint and re assemble...
It is what it is... my suggestion if you are trying to find a 2.2S, find one all together & running and with minimal issues...in these hard economic times, I am sure they are out there, you just need to find one.
Bob
I live for 911 tweaks...
Old 11-15-2009, 03:43 PM
