Santa Clarita, Ca.
Question 930 tensioners help
I'm getting ready to install my 930 tensioners and have a couple of questions;
1) It is REALLY hard to compress these. I assume they're supposed to be really stiff? It's even tough with the vice!
2) How do I know if the fail safety stops have been installed? Can you tell from the outside?
3) What is the purpose of the bolt in the side? Anybody got a cutaway view or one that's all apart?
Old 11-02-2009, 08:37 PM
They are hard to compress, a really big screwdriver is needed
The fail safe is a collar that attaches, usually red or blue. It has 2 pieces and it has 2 cap screws. It sits about 4mm above the tensioner base on the hydraulic pin after installation.
You cannot install the tensioner with the collar in place.
Bruce
Old 11-03-2009, 05:38 AM
