I've runs MSD's on our race cars since 1978 and never experienced a problem. |
Hook an MSD 6 AL up to an, unrecommended by MSD for the 6AL, MSD Pro Power coil and you will see the 6Al fail after about an hour of duty, don't ask me how I know this...but I suspect some failures stem from these mistakes.
Well just to update this, I'm going XDi via Don at EBS. ( Just to say so far, both Don at EBS and Richard at Clewett have been top blokes ).
964 Cams and 98mm Mahle high comp P+C's, twin plug heads and 964 bottom covers. Hope it all works!! Db |
What are you using of an intake?
Cheers |
Hi
Just the std intake set up. Why do you ask? Db |
If you were using carbs or ITB's I was going to suggest a larger cam to take advantage of them. But your build looks good!
Cheers |
Good, thats reassuring.
Db |
Go Go Bronco,dont forget you have a master engine builder on your side as well ;)
If you're twin plugging, you may as well go 100mm Nickies for a 3.5?
Not in within budget.
But if you have some you want to donate some ... lol I do have that set of 98mm Mahle RSR fitment pistons and cylinders in good shape ( I think 8 P's and 9 C's ) if any one out there wants to do a deal I would be interested. Db |
| All times are GMT -8. The time now is 12:18 PM. |
