Twin plug advice
Is there an alternative to the andial signal splitter?
looking for a complete set up for a 3.2/3.4 conversion. Crankfire systems seem too expensive which leaves me with the mechanical solution. I'm assuming that its a must to have some kind of splitter to ease the burden on the DME system. Anybody done anything different or should I bite the bullet and buy the Andial one? Regards David |
The "big 3" are:
1 - crank triggered systems, the 2 most common being XDI & Megasquirt II with EDIS 2 - a dual distributor system - usually modify a 964 distributor for triggering, and run run 2 CDI boxes & an some electronics to control advance (as the 964 has no mechanical advance) 3 - 12-plug distributor - modify an existing distributor or somehow source an original (and you thought crankfire was expensive). This setup also requires 2 CDI boxes (and associated HW) but doesn't require an advance controller as the distributor has mechanical advance. None of these options are cheap...
Don't Lift... Don't Lift... Don't Lift ![]() ![]() ![]() '75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade. |
twin plug
Long horn has good advice, I would add that Richard Clewett has some nice stuff available using Electromotive bits (I think this is the XDI he referred to) that is not too expensive and works really well.
Best of luck, Cole |
Try not, Do or Do not
Supertec has a great twin plug alternative.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
1966 - 912 - SOLD
If you like that one here's more.
Picture from the new shop coming soon.!!!! ![]() ![]() ![]() ![]()
GAFB
New shop?
Several BMWs |
Sorry Henry... I forgot you had that. I guess #3 should have included "buy a new 12-plug distributor"
And those are purdy
whats this kinda thing cost?
Wild Porsche Engine |
+1 for the Supertec twin-plug distributor.
That 3.5 twin-plug MFI engine is in my garage
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
3 restos WIP = psycho
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
You also have many different options for case, rods and induction. The short stroke 2.8 is a great engine especially for a long hood platform So building them offers great rewards. Just to give you some idea about price, a base using a 3.0 turbo or Carrera case would cost around $15 K. Add to that $3 k for twin plugging, $6K for modified production MFI and you start seeing a trend. If you want Ty rods add $2.5K. Ty valve $1.2 K. Built using our new slide valve system add $12-$18K depending on the pump. If you want one built using a 3.0-3.6 case you will need a Supertec SuperCrank and that will add another $3k or so. Please understand these are just general prices. If you are serious about building one of these gems we will be happy to negotiate something that fits your budget. That said: if your budget is $10K we will help you secure proper medication. ![]() ![]() ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-05-2009 at 09:25 AM.. |
These days, I have to ask the price of a "Happy Meal".
Henry,
Have you considered adding a boss for and electronic (bosch type) injector to your slide valve offerings? Then folks could use them with a modern ECU.... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
We can change the port size to suit the application as well. We also have stacks designed for use with an air filter housing for the daily driver. ![]() ![]()
Nice!!!!
I am wondering how much more power one can expect with slides vs standard ITB's with a throttle plated... Cool. Cheers
Wer bremst verliert
Cool pics and bits.
If you are intent on keeping your DME then I believe the Andial or similar box is your easiest choice. Adapting an EDIS system to fire from your DME might actually be the cheapest. If you make the leap away from the DME then you have even more options like Henry's or JB Racing's twin-plug distributor. They are both designed to perform both the triggering/timing side as well as the spark distribution function. You may be able to retain the DME's triggering of the spark but the distributor's firing. I'm not sure about that. If you go the twin-plug distributor route you need a pair of coils and a pair of MSD 6 boxes also (add ~$400) plus fabricating/adapting mounting panels. I dont know what an andial box goes for. Henry can quote you a price for his distributor, JB's cost me around $1250. The parts to do it from EDIS would be about $150.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy Last edited by JohnJL; 11-05-2009 at 10:07 PM.. |
To expand alittle.
I wanted to keep the DME at this point. I have sourced a 964 dizzy, was thinking about the Andial splitter so what else do I need to make it all work? Db |
You only need one MSD but you will need two coils. We mount the single MSD box under the drivers seat to keep away from the RF signal generated by the plug wire and it also keeps it clean & dry. We mount the coils on the relay board, removing it from the fan housing to isolate it from engine vibration. The other benefit is a clean engine bay. ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-06-2009 at 07:28 AM.. |
