Bill Verburg's Avatar
Originally Posted by ninesixfour View Post
Megaphones are just hollow tubes, no muffling.
Nope, megaphones are shaped, the taper and length and whether or not there is a reverse cone and the geometry of the cone end are all critical factors. Same thing w/ the merge collectors where the angle and length of the merges can make a big difference.
Bill Verburg
Old 11-15-2009, 05:53 AM
What do you think?
How about taking weight off the crankshaft somewhere?
The comment above that the Carrera 3.0 w/ the 6 bolt crank had more HP because it had a lighter crank Than the 9 bolt SC, made a lot of sense.
Could an SC have some pork in the crank? And where to remove it?
Thanks Mark
Old 11-16-2009, 05:49 PM
Thanks Mark
A lighter crank doesn't make hp which is measured at a constant rpm. It does allow freer reving. The difference in hp between the C3 and early SC was all freer flow exhaust, ignition and fuel maps
Bill Verburg
Old 11-17-2009, 03:44 PM
Thanks Mark
This wouldn't be allowed in a PCA stock class race car anyway.
Gone
92 C2
82 Euro SC race car
993 C4S 3.8
84 Euro Carrera
Old 11-18-2009, 09:45 AM
