Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
2.7L to 2.8 with Carbs
If you take a stock 2.7 and want to increase performance, it seems the going suggestion is 92mm P&C, with 964 Cam, Carbs and backdated exhaust. If you go to the 92mm P&C, you have to machine the heads, right? I think that is what I am understanding from Bruce Anderson's book.
To do the headwork, what is an estimated cost?
1976 911s Targa
1976 911s Coupe
Old 11-16-2009, 08:53 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Why would you use 964 cams? early S or Solex would be the way
The cylinders are slip in, what would you do with the heads, they should bolt right up, youre only opening 2.7 cyl 1mm of the wall.
Bruce
Bruce
Old 11-16-2009, 09:12 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
old style vs new style
Depends on what kind of pistons you get for the 2.8. Old 'honest to goodness' 2.8 pistons had crowns for the larger volume unobtainium 2.8RSR heads. So with 2.7 heads they have lots of compression and will touch at the edges. A chamfer on the heads is required. More modern versions exist that have 'correct' crowns for the 2.7 heads.
Building molecues or building cars... you do get more of first in every batch. A mole of porsches anyone?
Old 11-16-2009, 09:24 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Bruce's book talks about needing to widen the heads to 36mm from 32. I am not sure if that is for all set ups with bigger cylinders or specific to a certain setup. I was wondering if you increase the cylinder size, do you also increase the head size to be compatible.
1976 911s Targa
1976 911s Coupe
Old 11-16-2009, 09:31 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Tadd, thanks. I think they clears up what Bruce was saying in his book. I was thinking of having my 2.7 cylinders bored to 2.8 so I assume the clearance would stay the same and I could use the existing heads without machine work on them (other than clean up and valve job).
1976 911s Targa
1976 911s Coupe
Old 11-16-2009, 09:37 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
bored 2.7 cylinders
Do you have the CE ring grove? The cylinder gets mighty thin at 92mm and is prone to breaking off at the whiff of detonation. Mahle deleted the grove on there 92s.
Old 11-16-2009, 10:41 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Not easy to rebore Porsche cylinders and still have a Nikasil wear layer remain intact. Your choices are to purchase larger cylinders with a new Nikasil coating (so-called "Nickies") or purchase the requisite Mahle 92mm cylinders. However I think Mahle only provides these as a set with pistons.
Thus, an aftermarket piston (JE or other) along with larger cylinders begins the process.
Sherwood
Old 11-16-2009, 12:42 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Ln
I'm pretty sure that Charles (LN Engineering) can strip, bore, then recoat.
Hes going to strip and replate/hone as set of 92s for me, so tossing in a bore should be pie... but talk to the man first.
t
Old 11-16-2009, 01:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
