optimoly anti seize. Where do I purchase?
I am assembling a 3.0L (930/02 type) motor. I have the camshafts that use a hex bolt and washer to secure the drive gear to the camshaft. I'm told to use Optimoly anti-seize on the bolt threads and also on the cylinder head nuts. Where do I buy the stuff? Is there and alternative product available?
thank you,
Ed
Old 11-25-2009, 05:59 PM
304065's Avatar
Ed,
First of all WELCOME to the forum. You will find a lot of good information and helpful people here, including some professional engine builders.
Optimoly HT is made by Castrol and is distributed in Europe mostly. I haven't been able to find it in the USA. I think there is a Porsche part number but it's like $40 for a six gram tube.
Fortunately, the datasheets for Optimoly HT are available, and we can see that it's basically a copper-based high temperature ("HT") antiseize paste. As such, similar products by Permatex or Lubro Moly are good substitutes.
Here is the datasheet:
http://safetydatasheets.bp.com/ussds/amersdsf.nsf/0/30d6d20a9858fe3d8025707600504b25/$FILE/00019433000220003.pdf
In assembling my own engine I used Lubro Moly LM508, available from our host here for about eight bucks a tube. Works well on wheel hubs and exhaust system bits also.
Pelican Parts - Product Information: 2012-M19
Good luck!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-26-2009, 06:01 AM
Copaslip is very good too.
Google it and there are more places to buy it
Copaslip
http://www.efodiastiki.com/files/METAL%20MAINTENANCE%20&%20REPAIR/COPPER%20ANTI%20SEIZE.pdf
Pegasus - Copaslip Antiseize Assembly Compound
Old 11-26-2009, 01:48 PM
Thanks guys. I appreciate the info
Old 11-28-2009, 05:35 PM
