Daviboy's Avatar
Case Repairable?
Hi guys please look at the pics and give opinion if this case is repairable. The cylinder seal area on #2 is badly damaged but not as bad as it looks in the close up!!!
Davy
82 911 SC Targa Sold
12 Audi A5 Sportback 3.0 TDI Quattro
03 996 C4S
Old 05-08-2010, 11:21 AM
peppy's Avatar
Probably can be fixed, but a used case would get my vote.
Better opinions will be offered I'm sure.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 05-08-2010, 12:10 PM
That can be welded and remachined by a competent and experienced individual
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-08-2010, 12:41 PM
sprbxr's Avatar
Send a message via Yahoo to sprbxr
I have repaired worse. Hard part is getting the oil out of the porous aluminum. When you heat it with a tig, the contaminants come to the surface of the molten Aluminum and make it impossible to get a decent fill. By the time you pay to have it welded then get it machined, then checked and machined to make sure the case is within spec, you may have as much in it or more than a decent used case might cost.
Justin
Old 05-08-2010, 02:51 PM
Daviboy's Avatar
Thanks Steve from you this is good news I trust your judgement!
Davy
03 996 C4S
Old 05-08-2010, 03:01 PM
Daviboy's Avatar
On another note I am still waiting on my re-build book so can someone post the specs for the inner case dimensions i.e. crank bearing specs etc
Davy
03 996 C4S
Old 05-08-2010, 03:02 PM
