Case Repairable?
Hi guys please look at the pics and give opinion if this case is repairable. The cylinder seal area on #2 is badly damaged but not as bad as it looks in the close up!!!
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S Last edited by Daviboy; 05-08-2010 at 11:23 AM.. |
Probably can be fixed, but a used case would get my vote.
Better opinions will be offered I'm sure.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
That can be welded and remachined by a competent and experienced individual
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I have repaired worse. Hard part is getting the oil out of the porous aluminum. When you heat it with a tig, the contaminants come to the surface of the molten Aluminum and make it impossible to get a decent fill. By the time you pay to have it welded then get it machined, then checked and machined to make sure the case is within spec, you may have as much in it or more than a decent used case might cost.
Justin |
Thanks Steve from you this is good news I trust your judgement!
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
On another note I am still waiting on my re-build book so can someone post the specs for the inner case dimensions i.e. crank bearing specs etc
