Head Studs
Doesn't anyone have experience with Raceware compared to ARP head studs. I am building a 2.5, 11:1, 911 engine for PCA racing.
Rich
Old 12-09-2009, 08:07 AM
Try not, Do or Do not
Henry Schmidt's Avatar
You should add Supertec head studs to your inquiry.
They are available through Pelican Parts.
Cheers
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-09-2009, 08:40 AM
BURN-BROS's Avatar
+1 on Supertec's studs. IMHO the best product available.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 12-09-2009, 09:26 AM
3 restos WIP = psycho
kenikh's Avatar
+1, as well. None better.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 12-09-2009, 09:52 AM
Rich, kinda off post but will ask anyway. I'm in the process of the 2.5 build myself. What are you going to use for cams? and what size carbs are you going with?
BTW I'm the slow poke gulf blue and orange 914-6 that you always have been nice enough to help out up at Putnam Park.
1970 914-6 GT Track Car
1974 IROC Track Car
1987 911 Targa 3.2
2008 BMW X5
Old 12-09-2009, 01:28 PM
I am using the cams I had ground for my 2.2. They are Web cams #120 104 that are like S cams but not as torquey. They seem to work well. I am using PMO 40 carbs. I had to rejet and change the chokes. If interested I can get the information for you as to the exact jets. My motor is 11:1 using a 2.7 crank and I think 86mm pistons. Whatever makes 2.5. You can also build a 2.5 using a 2.0 to 2.4 crank and 2.7 pistons. This make a higher revving motor but less torque. If you buy carbs and need intake manifolds I have a new set of PMO intakes that I can let go at a good price.
Good Luck with the project.
See you at the track.
Rich
Old 12-09-2009, 02:34 PM
