LinkBack | Thread Tools | Rate Thread |
Rick
longest time between decision to rebuild and the engine actually on the ground
Decided to rebuild my 1970 911E engine just about the same time that my son was born. You can guess which project was delayed.
Following several posts on this forum, and the 911 technical forum, and help from Wayne's books, I am now glad to report that the engine is on the garage floor and I still have all my fingers attached. Tear-down starts tomorrow! ![]() BTW, my son turns 30 this summer... Rick |
Whew- I thought the guy in the photo was your son until I kept reading!
![]() I feel better about my 5-year delay! _curt
66 912 ... 2.7 conversion (What a blast!) 79 928 5-spd (sadly, sold) 85.5 944 5-spd (sadly, traded for 928) www.curtfranklincreative.com |
Congrats. Now when we get our motors back in we'll have to meet up for a drive.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
I hope he's not 60 when you're ready to put it back in.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Been waiting to time the cams for about 2 years. Found rust on one of my cast-iron rockers the other day, that's easy enough to pull and detail. Fortunately I used Aeroshell Fluid 2F, which is an aviation corrosion-preventive oil, on all the internal parts, and LPS IV corrosion inhibitor on the big stuff like the flywheel. Easily comes off with citrus-based cleaner when the time comes to mate the clutch.
Persevere!
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
So your son was old enough to help!
Landon - 1972 911T |
Boy this subjects corresponds perfectly to my next question....
How long is assembly lube generally good for, once applied? My project is moving slower then i had initially anticipated. Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC Suspected track car Last edited by LeakProof; 12-15-2009 at 11:59 AM.. |
Rick I think you won that contest....the rebuild should be all down hill from here on.
![]() Like a ball rolling down a hill that is. I'm 2 years in on mine and am still collecting parts.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
My biggest problem is fighting this sluggish economy, it's not really cooperating with my rebuild budget.
Priorities blow. ![]() Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC Suspected track car |
My 83 has been off the road for 8 years this month, boy time flies.
Lorne m.
83 SC |
Rick
Update on the engine rebuild:
Validated the advice in several books about mounting the engine on the engine stand. Most advised three strong friends and a six-pack. Did it by myself, but couldn't walk for most of the next week. Here is a picture of my son working on the engine: ![]() Now comes the part about getting the 40 year old exhaust manifold barrel nuts to part company with the head studs. So far, we have rounded off the 8 mm Pelican Parts special tool as well as rounding off the inside of the nut. This is after soaking in PB Blaster and WD-40. Using the impact wrench was satisfying, but ineffective. Any suggestions? Chisel? Drill out / off? Use a cut-off wheel to cut the heat exchanger and header off? Thanks Rick
Rick 1970 911 E purchased in Stuttgart in 1973 |
Mo money = mo parts
If that doesn't work, I would dremel the nut on the stud, not the stud. You don't need it to come off, just weaken the nut. Then heat as above. You can heat the stud latter to get it to come out. Keep it cherry, heat is your friend. If neither of those work, cut off the nut at the flange, then heat the stud to remove. Drilling would be the last resort. It's definitely the biggest hassle, most work and highest risk approach. You may want to pay a shop if you get to this point.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Rick
Tuesday Update:
Thanks for the guidance! Went to Lowe's, bought MAPP gas cylinder and torch and a thing that the tool guy called an easy-out (drill a hole, then insert the tool with the threads reversed so that the nut/stud turns out). Used the adjustable BFW (normally used on the tractor) to turn the easy-out as the tool square end did not fit my socket wrench. The first three studs came right out, so one heat exchanger has bit the dust. The other side remains recalcitrant. We quit for the day as I was getting to the 'get a bigger hammer' stage. Soaked the nuts again with PB, and called it a day. Rick
I used lots of heat (MAPP Gas is a must) and got most of them. Get them orange hot!
But some wouldn't budge, so I used a 1/8" diameter carbide burr, to cut a slot in the nut. With a cold chisel and hammer. you should be able to turn the nut. Helps if the nut is cut almost all the way through. You'll be sucessful, if the nut starts to split, and the threads become loose. Ultimately, one broke. I used a set of increasingly larger carbide drills to drill out the center of the stud, and when I got close, I used the 1/8" carbide burr to carve the inside of the stud, until I could just see the imprint of the thread bottom. At that point you can pull the remaining portion of the thread out like a heli-coil. There are also tools out there that can be used to drill out the stud. The tool guides the drill, instead of my freehand cutting.
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. |
Rick
New Year's Day Update:
Thanks for the advice on the header barrel nuts! I was able to finally remove the second header using the drill / easy-out tool (not really easy) without resorting to the MAPP gas torch that I bought at Lowe's. This is good as the engine reeks of old oil and PB blaster. Got the valve covers off, chain covers off, all other ancillary bits and pieces off, removed the flywheel then re-installed the flywheel when I realized that I needed it to hold the crank in place when the cam nut is removed. Loosened the valve adjustment. Tried to remove the cam nut. I have the right crowfoot and the P202 tool to remove the nut. Wayne's book says to slowly apply pressure counterclockwise to remove the nut while holding the crowfoot steady. I did this without results. Is it OK to use the impact wrench on the nut with the P202 tool? It looks like an impact socket. Will this damage the cam in any way? Or, should I just get a bigger breaker bar on the P202? Thanks again for the advice on this thread. The tear-down has gone faster than I anticipated. Rick
Richard |
Rick
The adventure continues. Today was a good day after I finally got the crow foot / P202 tool trick working.
ready to take the pistons off the rods tomorrow. Finished all the top end removal today. This picture shows pistons and cylinders that have not been fired since 1980 or so. The rust in the one cylinder is from the header removal as the exhaust valve was open on this one. Some show carbon build-up, others have what looks like white sand on the piston face. After removing the cylinders, the cross-hatching is still visible on the piston walls. The sides of the pistons are clean. Most of the driving was high speed in Europe. Probably less than 1,000 miles at US highway speeds. ![]() ![]() Still not sure whether to clean and re-use or get new cylinders and pistons (87.5mm / 10.3 CR). I will keep the MFI and the E cam. Thanks again to all who helped me on the tricky parts. I will start a new thread following the report from the machine shop on the condition of the case, crank, and heads. Rick
