Home of the Whopper
What to build for '71E?
Going in a '71E for a daily driver with some mountain roads thrown in.
I have a complete 2.2E and 2.2S engine with MFI. Originally I was going to stroke the 2.2E to a 2.4E. Now I am thinking I may use the 2.2S heads, throttle bodies and intakes to open it up a little bit. Will the larger ports hurt the bottom end too much around town? Anybody do this?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 12-19-2009, 12:14 PM
jluetjen's Avatar
I think that a 2.4E with S heads would most likely work fine since the E heads seemed to choke off the engine a bit. You'll most likely wind up with a 2.4E with a torque curved shaped more like a 2.0E's, just shifted up some.
To put it differently, it will be a little bit peakier than a 2.4E with stock heads. You might even want to try going with a DC40 or DC60 cams.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-23-2009, 02:43 PM
