JoeMag's Avatar
CR change by shaving heads
Anyone have a formula(s) for calculating what you'll get for a new compresison ratio by knowing original compression ratio and motor size and shaving some value of heads?
Old 12-22-2009, 03:57 PM
harold
Stroke volume= Vs
Combustion volume = Vc
CR (compression ratio) = (Vs+Vc)/Vc (if you know the CR you can determine the Vc)
Shaved height= H
delta Volume trough shaving = Vd= (0.25**Dē)*H
=3.14 and D is cylinder diameter
New Cr = (Vs+(Vc-Vd)/(Vc-Vd)
hope this will help (and this is correct...)
Old 12-23-2009, 03:37 AM
JoeMag's Avatar
Yes that make sense... I was forgetting Vc in the numerator of CR in what I was doing. Below is example for 993 for shaving 0.010" to 0.020" from heads. Frankly I was surprised at how much CR went up.
Old 12-23-2009, 05:21 AM
harold
yes, the effect goes up exponential with the CR. I was doing this calculation on a 3.3 turbo with a CR of 7.5 and there the effect is not that big.
Old 12-23-2009, 06:43 AM
Woodland Hills, CA
And then there is valve to piston clearance and deck heighth checks...
Old 12-23-2009, 10:39 AM
