Dr J's Avatar
Installing injector sleeves
Is there any trick to this? I read some posts, but everyone is asking about how to remove them rather than installing. The CIS is out of the car, I put in new o-rings, soaked them in fuel, the sleeve goes in but I can't get it to remain in all the way. It wants to come out 1/8 inch or so above the intake runner. I used a socket on the inside step and a clamp to press it in, but it comes back out a bit. Since the engine will be supercharged, I don't want to lubricate the O-ring. I don't want it popping out later under boost.
John
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 12-30-2009, 05:55 AM
Less brakes, more gas!
euro911sc's Avatar
You have to pean it in. I used an automatic punch to make 3 small imperfections (peens) around the top of the lip of the intake pipe where the sleeve goes in to the pipe (looks like factory did it). You would have filed these off to get the sleeves out to begin with. I'll see if I can find a picture...
Not peened:
Peened, see the dimples around the top and how the circle is deformed now:
Why did you soak them in gas??
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 12-30-2009, 06:23 AM
Dr J's Avatar
I did grind off the stakes with a dremel to get the old ones out. I do know about peening them in, but the problem is that in your first picture I see the sleeve is at least flush with the intake. In my case, when I press it, in, it comes back out and doesn't stay flush like your first picture. It's like the rubber in the o-ring doesn't seat and so pushes it back out.
I soaked in gas because that is what you are supposed to do to the injector o-rings so I figured to do the same with the idea that it would be a type of lubricant to insert it. Unfortunately, it evaporates very quickly.
BTW, thanks for the quick reply!
Old 12-30-2009, 06:44 AM
injectors
John, you need some type of lube like soap or silicone grease, when they snap in place you won't blow them out with low boost.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 12-30-2009, 02:55 PM
Dr J's Avatar
Got them in, thanks to all for the help!
Old 12-30-2009, 06:01 PM
euro911sc's Avatar
I'm pretty sure I used some sily-cone based lube on my rings. glad you were successful!
best regards,
Michael
Michael
'13 Cayenne GTS
Old 12-30-2009, 07:15 PM
