Unhappy 85' Carrera ~ over revved engine
Hi, this is Bob the knucklehead who over revved his engine at Thunderhill last spring causing:
This...
That is from the #1 cylinder and this is what I think I know so far. The rest of the spark plugs, cylinders 2-6 are undamaged. I haven't been able to compression test 2-6 yet but I don't think it will be an issue.
I drained clean oil (no metal) from both the case and oil reservoir ; so I'm thinking the oil pump is working and the case is undamaged.
I'm hoping the only damage is to the #1 cylinder, piston, valve(s), rocker arm, and ??? etc...
Is that a reasonable guess?
I just started a new career path mid last year, because of that I need to build a strong engine fix with little $. Boy if that isn't an Oxymoron.
Anyway ~ I should have the engine out tomorrow.
Let the games begin.
85' 911 Coupe: Rebuild complete.
Old 01-01-2010, 06:26 AM
Chain fence eating turbo
Does the motor run at all? If not, I hate to say, you most likely floated the valves and the bent the exhaust valves.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-01-2010, 07:35 AM
Yes it runs, smoke, noise etc., but it does run.
Old 01-01-2010, 03:34 PM
BURN-BROS's Avatar
I would be very concerned about the piston,rod, and rod journal of that cylinder.
I would also replace all the rod bolts after I completely disassembed the engine.
You never know, sometimes the rod journal makes it through the carnage with little damage. Good luck.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 01-01-2010, 03:42 PM
efhughes3's Avatar
I didn't damage my pistons at all, didn't break any rockers, but bent all of my exhaust valves slightly when I did the same.
As Aaron mentions, the rods being checked and resized and new rod bolts are usually part of the repair list.
Mine ran too, even with the bent valves. I hate to say it; you're going to have to get in pretty deep. If you jabbed a plug like that, I would assume you've got issues in at least some of the other cylinders.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-03-2010, 05:24 PM
dshepp806's Avatar
keen, keen eye on that piston....
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-03-2010, 07:02 PM
Thanks for the input everybody. After the heads up on the pistons//rods/rod bolts and etc... I had a chance to sit down, read a little, think a little and decided I will cut corners to save $ every place possible.
Ok so I'm pretty sure I am done cutting corners now. That adapter is about as nifty as I get so I had to share it.
Here let me save you the trouble.
Anyway I have come to the obvious conclusion that it would (I would) be foolhardy not to go thru and re-build the entire engine.
And once again, thanks for the input. (I get the feeling i will be saying thank you a lot as time goes bye)
Speaking of Bye for now...
Old 01-05-2010, 11:47 PM
By the way
Smilies
should be mandatory on every post!
Old 01-05-2010, 11:52 PM
Sorry, sleep deprivation!
That's my story and I'm sticking to it.
Old 01-06-2010, 12:10 AM
911 tweaks's Avatar
happy trails ..."while you are in there"...
I live for 911 tweaks...
Old 01-06-2010, 04:25 AM
efhughes3's Avatar
Yeehaaa!! Another one joins in.....
Ed Hughes
2015 981 Cayman GTS
Old 01-06-2010, 05:50 AM
Here from the outside looking in:
Cylinder one on the right side with the nice crack in it.
Old 01-06-2010, 09:57 AM
Now from the exhaust side:
Most of the valve, gone.
Old 01-06-2010, 10:01 AM
Ouch!
Old 01-06-2010, 04:01 PM
Certified Porscheaholic
777joee's Avatar
Well now.........
Bob,
Sorry for your loss. The crack in the cylinder is a bit hard to take.......OUCH!
This is now a shameless plug for me as I have a VERY nice 1978 3.0L motor that a bit over 15K ago had 16K spent on a total rebuild. If you or anyone else is interested let me know.
BTW I'm in Sacramento. I would take your dead 3.2 in partial trade.
Dave Mitchell
Proud owner of "The Beast"
2010 Intermeccanica Speedster with 100% 1980 Porsche 3.0L power and suspension.
http://photobucket.com/IM-6build http://www.intermeccanica.com/
Old 01-06-2010, 07:23 PM
Now with the valve covers off and the same #1 cylinder intake side of the rocker:
By Saturday I should be in the case.
Old 01-08-2010, 02:32 AM
911 tweaks's Avatar
wow... sorry to bring up the actual event, but for us all to learn from this, do you know how hi it rev'd and for how long and how many times have you over rev'd and lastly, this is a stk 3.2 engine, right??
Sorry again for this happening but think of the $$ you will save if you do the work yourself...you can now buy upgraded parts!!! :-)
Bob
Old 01-08-2010, 04:30 AM
efhughes3's Avatar
That is one nasty hit. You're going to need to check everything very carefully. I've always thought I caught mine extremely fast, but felt I was lucky to get away with only bent exhaust valves and no other breakage. I still went through each and every piece of motor to make sure.
Ed Hughes
2015 981 Cayman GTS
Old 01-08-2010, 05:39 AM
Super Moderator
cstreit's Avatar
That must have been one hell of an overrev. Sorry for your pain, been there several times myself. Good luck on the rebuild!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-08-2010, 01:01 PM
Yes 3.2... No clue what the rev was other than, right at red line 3rd into 4th with the pedal pinned. The only problem, I went into 2nd instead of 4th. The money shift, more like the dummy shift.
911 tweaks // No worries on the questions, whats done is done.
efhughes3 // Yeah, me too; I thought I caught it fast. Guess not.
This happened just after the blind right hand #9 at Thunderhill Raceway. There was no noise, vibration nothing at first. I actually went another full lap (3 miles, maybe even two laps) at speed before I saw smoke and felt the power loss. At first I wasn't sure what caused it because, (I caught it so fast~lol), of of the delay between shift and ruin. Adding insult to injury I limped it in not wanting to shut down the track. What a Jack-butt maneuver that was.
One thing is for curtain. I am replacing the shift linkage with one of the aftermarket setups some of my friends are using. Don't know the mfg off hand. I do know it is spring loaded so you have to pull it past the spring tension for 2nd gear.
Time to get to work. As soon as I have the case split etc I will be back with pics seeking advice on how to proceed.
Old 01-08-2010, 04:55 PM
