-   -   Ruby's engine rebuild-Rev1 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/520499-rubys-engine-rebuild-rev1.html)
efhughes3 02-05-2010 09:56 PM
Thanks Jeff. The hard part is over, the heavy spending is done!
johnnywishbone 02-11-2010 09:31 AM
email sent
efhughes3 02-21-2010 01:33 PM
Well, finally, the work has started. Got the engine out via a garage party yesterday:
http://forums.pelicanparts.com/uploa...1266787833.jpg
http://forums.pelicanparts.com/uploa...1266787848.jpg
http://forums.pelicanparts.com/uploa...1266787861.jpg
Started stripping it down today. I'll do some exterior cleaning next weekend before opening any of the internals up. I'm not opening the case, so cleanliness will be a prime concern. It's almost harder doing it this way than stripping everything down and making it as new, then building up from there. Everything that bolts to the case will be made as new, but again, caution is prudent.
http://forums.pelicanparts.com/uploa...1266787988.jpg
http://forums.pelicanparts.com/uploa...1266787998.jpg
efhughes3 02-24-2010 03:10 PM
Well, how is this for a bit of a sobering surprise? My motor mount or console is severely cracked. It looks like heat treating gone wrong. Interesting to note, Pete Zimmermann relayed to me that he saw this happen to a few '84's, maybe Targas, a number of years ago. It was bad enough that they made it a point to inspect the mount on any car they worked on. I've had Ruby's engine out twice, the most recent two years ago-no issues were evident at that time.
Or, I can say I'm thinking it was the severe torque she already put out, coupled with my driving extracting the most out of her...:rolleyes:
At any rate, something to look out for:
http://forums.pelicanparts.com/uploa...1267053030.jpg
http://forums.pelicanparts.com/uploa...1267053047.jpg
Buckterrier 02-24-2010 03:27 PM
Wow Ed, good news/bad news deal. Expensive item, (aren't they all on our girls?)
efhughes3 02-24-2010 03:36 PM
Only expensive new...I found several for $75. I'm just going to make sure and keep an eye on this when the motor is back it.
Buckterrier 02-24-2010 03:41 PM
very cool. When I had the 3.6 rebuilt the shop welded a gusset on the right, (passenger side), support. I guess they've seen that side break from the torque.
efhughes3 02-24-2010 03:44 PM
Hmm, that is interesting. I may check into this. The fact that this cracked like this would lead me to believe it is high strength steel or heat treated, which means I'd not be quick to weld myself. But worth exploring, thanks Mark.
Buckterrier 02-24-2010 04:13 PM
Ed, I looked at the build sheet. He say they 'modified the rear engine hanger'. I'll go into the garage and see if I can get a picture.
Buckterrier 02-24-2010 04:15 PM
Opps you are talking motor mount. Could still be worth looking into depending on what kind of torque you are going to have. I believe Silin is at 258.
Buckterrier 02-24-2010 04:28 PM
Modified rear hanger
Here it is Ed. If you'd like I'll talk with the shop and find out what all they did. I believe they cut a wedge out then fit the gusset. May be mistaken.
http://forums.pelicanparts.com/uploa...1267057669.jpg
efhughes3 02-24-2010 05:03 PM
Ahh, I believe I've seen beefed up horizontal bars. Mine is the chunk that bolts to the case and covers the crank pully. I've called it the "motor mount", but I think PET calls it a "console".
lindy 911 02-25-2010 06:43 AM
Mine was cracked on my '78 SC but not as bad. I had the crack ground out and TIG welded. Cost about $30 to fix and it's right. I don't believe the part is heat treated.
Lindy
efhughes3 02-25-2010 07:50 AM
Thanks Lindy, nice to know someone else has seen this. I should probably post this on the main forum. Good warning for folks to inspect theirs.
efhughes3 02-27-2010 03:52 PM
Last night, I ordered a few hundred $ worth of misc from Pelican Parts. Today, I took the headers off, gave her a sponge bath with several cans of CRC brake cleaner, took the camlines, oil cooler and valve covers off-then "bled" her. Tomorrow I'll hopefully get her stripped down to a shortblock and then work on cleaning the head and cam towers. Then-start going in the other direction. It amazes me how many part come off these suckers!
http://forums.pelicanparts.com/uploa...1267314598.jpg
http://forums.pelicanparts.com/uploa...1267314611.jpg
http://forums.pelicanparts.com/uploa...1267314624.jpg
http://forums.pelicanparts.com/uploa...1267314639.jpg
http://forums.pelicanparts.com/uploa...1267314650.jpg
http://forums.pelicanparts.com/uploa...1267314662.jpg
http://forums.pelicanparts.com/uploa...1267314678.jpg
johnman001 02-27-2010 09:26 PM
Good looking engine. Makes mine look filthy. What are you going to do with your existing P/C?
efhughes3 02-28-2010 07:42 PM
Today, I removed the cam drive hardware, chainboxes and head/camtower units off today. I really goofed up though-almost. I didn't pull the dowel pin from the cam sprocket like I meant to before pulling the sprocket. I immediately remembered it when I got the sprocket off the cam, and it was MIA. I was sorely disappointed in myself. I tipped the motor on end, and reached into the case with a magnetic pickup to try and nab it, but got nothing. I tapped on the bottom of the case gently to try and dislodge it, but that didn't do it. I was well into my vulgar vocabulary when it came rolling out of the case and onto the ground. Got to be more careful!! I also pulled the clutch which looks great after 17,000 miles and 5 years.
No progress until next Saturday. I'll take the heads apart then, and get a plan together for cleaning them. I'll probably take them to a shop for cleaning. I may then put the new p's and c's in too.
http://forums.pelicanparts.com/uploa...1267414858.jpg
http://forums.pelicanparts.com/uploa...1267414881.jpg
http://forums.pelicanparts.com/uploa...1267414897.jpg
http://forums.pelicanparts.com/uploa...1267414960.jpg
efhughes3 02-28-2010 07:43 PM
John-I haven't gotten that far yet in my thinking.
Jeff Alton 02-28-2010 09:01 PM
Ed, looking good!
What type of floor is that in the garage?
efhughes3 03-01-2010 07:36 AM
Originally Posted by Jeff Alton (Post 5211024)
Ed, looking good!
Thanks Jeff
It is Racedeck tiles. So far-so good after almost two years. Mops up every 6 months and looks new. Floorjacks and jackstands do need some protection.
