-   -   Ruby's engine rebuild-Rev1 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/520499-rubys-engine-rebuild-rev1.html)
efhughes3 01-09-2010 07:39 AM
I rebuilt the engine a couple of years ago keeping the stock P's and C's as they were fine-and I needed to keep my budget at the number I had in mind at the time. No real expense other than that was spared to build a good solid 3.2. She runs great, and I've probably got 7 or 8000 miles on her in the 2 years since the build.
But I have a slight leak (bristle from the brush used to spread sealant?) between the head and cam tower at #3. I've not been motivated to fix this as I'll end up having to tear down the top end on the LH cylinder bank, and she is so much fun to drive!
Anyway, yesterday I decided to get to these new P's and C's for a bit more power, which will motivate me to move on this. Mahle 98's in 10.5:1 compression. I'll also go to twin plug via an Andial splitter setup-I'd machined the heads for the extra plugs when I built the motor. I'll probably look to start late in Feb or early March. I'm going to strip her down to the case-no need to split it-clean, inspect and assemble.
I'll document this as I go. :D
http://forums.pelicanparts.com/uploa...1263051489.jpg
http://forums.pelicanparts.com/uploa...1263051530.jpg
jpnovak 01-09-2010 12:35 PM
Ed, You will have lots of valve clearance with those pockets... HInt hint, wink wink...
New cams?
efhughes3 01-09-2010 12:43 PM
I hear 'ya! I did cams on the first go.....got the DC19 profile which has a bit more lift than a 964 grind from John @DRC. I really only need to think about doing some work on my intake manifold to help with the increased capacity.
911 tweaks 01-09-2010 01:01 PM
can't leave well enough alone here huh Ed... ;-) its just a minor oil leak, right...
I will follow your build as you do a great job writing up your journey...
Bob
911Freak 01-12-2010 03:22 PM
SUB'D
Looks like this should net some nice #'s!
175K911 01-12-2010 04:42 PM
Hey Ed, those are probably about the most expensive boxes to land in your garage aren't they? Have fun with the build. I just finished taking mine down to the case today and will split the case and pull the rods in a few weeks. Thank heavens for the winter season to pull off projects like this.
efhughes3 01-12-2010 05:10 PM
They are very expensive. My rebuild was right at five figures, and this is going to be 3/4 of that again with the P's/C's, ignition, clutch, injector cleaning, etc.
Winter? That is the big dilemna! When do you take a perfectly good 911 offline in San Diego County?!?! :confused:
Good luck on your build.
Jeff Alton 01-12-2010 05:32 PM
Ya, I saw your pics of the new years day drive and commented to Dee and Wade that "we could live there"....
Cheers
efhughes3 01-12-2010 05:47 PM
Just to keep us honest down here-we've been in the 70's since the end of '09-the El Nino cycle may be starting next week, so it may be a wet spring.
175K911 01-12-2010 08:13 PM
Go ahead, rub it in. If it wasn't for Chicago winters, I'd never find the time to do the projects. But it does mean working in an unheated garage when it's -6 out. Today it was 25 out and I got the garage temp up to 48, downright toasty.
You're going to have a really fun car when the engine's all done. You're building the engine I'd considered before going the 3.6 route. Will you dyno it when done?
efhughes3 01-12-2010 08:42 PM
I hope to dyno it soon after with Mr. Wong present.
Buckterrier 01-17-2010 05:52 AM
Boy... I envy you guys that have the courage and skill to do your own rebuilds. I know my limitations and engine work is not within them. I do enjoy the cosmetic side of things though.
Will enjoy your write-up Ed
Oh... I do change my own oil :D
efhughes3 01-17-2010 01:12 PM
Courage and Ignorance!
dshepp806 01-21-2010 06:00 PM
Fear & Loathing on the Porsche Trail ?
We'll keep the eye out for your progress, Ed.
Best,
Doyle
efhughes3 01-21-2010 06:12 PM
Well, progress is that the jewels arrived at the house today http://forums.pelicanparts.com/support/smileys/nuts.gif :
http://forums.pelicanparts.com/uploa...1264126283.jpg
911 tweaks 01-21-2010 06:43 PM
looks great Ed...whats up w/ the balck board pictured there...twin plug controller??
Also, thx for the travel info tips...I'll call you if you can pm me your #.
Bob
efhughes3 01-21-2010 06:49 PM
Yep, that's a splitter for the DME to run the twin coils.
TibetanT 01-22-2010 08:32 PM
There you go again...having fun in a warmer climate. Ha.
Those are very nice P/C's you have acquired!
Good luck with the rebuild. Looking forward to all the pictures and progress.SmileWavy
efhughes3 02-05-2010 07:28 PM
It starts on 2/20:
http://forums.pelicanparts.com/porsche-911-technical-forum/525113-san-diego-area-escondido-engine-drop-2-20-invitation.html#post5168578
Jeff Alton 02-05-2010 09:49 PM
good luck, Ed, I am sure all will go well!
Wish I could be there...
Cheers
