Ruby's engine rebuild-Rev1
I rebuilt the engine a couple of years ago keeping the stock P's and C's as they were fine-and I needed to keep my budget at the number I had in mind at the time. No real expense other than that was spared to build a good solid 3.2. She runs great, and I've probably got 7 or 8000 miles on her in the 2 years since the build.
But I have a slight leak (bristle from the brush used to spread sealant?) between the head and cam tower at #3. I've not been motivated to fix this as I'll end up having to tear down the top end on the LH cylinder bank, and she is so much fun to drive! Anyway, yesterday I decided to get to these new P's and C's for a bit more power, which will motivate me to move on this. Mahle 98's in 10.5:1 compression. I'll also go to twin plug via an Andial splitter setup-I'd machined the heads for the extra plugs when I built the motor. I'll probably look to start late in Feb or early March. I'm going to strip her down to the case-no need to split it-clean, inspect and assemble. I'll document this as I go. ![]() ![]()
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
I would rather be driving
Ed, You will have lots of valve clearance with those pockets... HInt hint, wink wink...
New cams?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I hear 'ya! I did cams on the first go.....got the DC19 profile which has a bit more lift than a 964 grind from John @DRC. I really only need to think about doing some work on my intake manifold to help with the increased capacity.
can't leave well enough alone here huh Ed... ;-) its just a minor oil leak, right...
I will follow your build as you do a great job writing up your journey... Bob
I live for 911 tweaks... Last edited by 911 tweaks; 01-12-2010 at 03:57 PM.. Reason: wrong name...sorry Ed |
Capitalist and Patriot
SUB'D
Looks like this should net some nice #'s!
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
Hey Ed, those are probably about the most expensive boxes to land in your garage aren't they? Have fun with the build. I just finished taking mine down to the case today and will split the case and pull the rods in a few weeks. Thank heavens for the winter season to pull off projects like this.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Winter? That is the big dilemna! When do you take a perfectly good 911 offline in San Diego County?!?! ![]() Good luck on your build.
Ya, I saw your pics of the new years day drive and commented to Dee and Wade that "we could live there"....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Just to keep us honest down here-we've been in the 70's since the end of '09-the El Nino cycle may be starting next week, so it may be a wet spring.
You're going to have a really fun car when the engine's all done. You're building the engine I'd considered before going the 3.6 route. Will you dyno it when done?
I hope to dyno it soon after with Mr. Wong present.
Boy... I envy you guys that have the courage and skill to do your own rebuilds. I know my limitations and engine work is not within them. I do enjoy the cosmetic side of things though.
Will enjoy your write-up Ed Oh... I do change my own oil
O2 In Sully We Believe |
Courage and Ignorance!
Fear & Loathing on the Porsche Trail ?
We'll keep the eye out for your progress, Ed. Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Well, progress is that the jewels arrived at the house today
looks great Ed...whats up w/ the balck board pictured there...twin plug controller??
Also, thx for the travel info tips...I'll call you if you can pm me your #. Bob
I live for 911 tweaks... |
Yep, that's a splitter for the DME to run the twin coils.
There you go again...having fun in a warmer climate. Ha.
Those are very nice P/C's you have acquired! Good luck with the rebuild. Looking forward to all the pictures and progress.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
good luck, Ed, I am sure all will go well!
Wish I could be there... Cheers
