RSR.guy's Avatar
Arrow 993 Mechanical Rocker Conversion Question
Guys,
When converting 993 valve train to mechanical rockers, does the bushing oil hole stay in place...or do you remove it? (i.e. install a bushing that is not drilled for oil feed)
Cheers, Chris
Old 01-21-2010, 10:12 AM
BURN-BROS's Avatar
They must be blocked.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 01-21-2010, 10:25 AM
RSR.guy's Avatar
Perfect. Thanks Aaron!
Old 01-21-2010, 10:31 AM
BURN-BROS's Avatar
No problem! Cheers!
Burnham Performance
Old 01-21-2010, 11:07 AM
