Case savers
Trying to mock up the head studs, cylinders, towers and chain boxes. The case has case savers installed by Ollies, installing the head studs they will go down to a height of 137mm they get very tight beyond this point. I ran a tap down the case saver and goes down easy untill the bottom of the case saver at this point it gets tight and feels like it is cutting new threads this is where I've stopped, don't want to mess this up. Any cautions at sending the tap through the case saver? The studs do need to go down all the way to the 135mm mark or they protrude to far up the head nut. Do the case savers threads at the bottom lock the stud in place or should the stud thread through the saver?
Old 01-22-2010, 05:33 PM
abit off center
cgarr's Avatar
Don't run a tap through it. The case saver is tight at the bottom, just run it in past the case saver and set it at 135
______________________
Craig
G2Performance
Old 01-22-2010, 05:45 PM
Good to know, I had this feeling I didn't want to run the tap through it.
Old 01-22-2010, 05:47 PM
