beancounter
jwasbury's Avatar
Cylinder cooling tins - can I get a ruling?
The patient is a 1979 turbo engine. Using 100mm LN Engineering jugs in place of the factory 1/2 finned Mahles. I'm uncertain of the fit of the factory cooling tins.
You can see the air gap near the "head" end of the cylinder is pretty large. The cooling fins on the factory jugs fit into the "steps" of the tin perfectly, but not with these. At the top of the piston, I couldn't get the spring clips in that hold the tins in place either...the slot at the top of the tin doesn't seem to protrude above the cylinder enough.
So I tried a little trimming on the tin...
Somewhat better fit near the "head" end, but now a large gap down at the base of the cylinder. Not sure if this is an improvment or not. I've gained some room at the top so I can install the spring clips.
This is the trimmed piece. Looks good from this angle to me, much closer to how they sit on the factory cylinders than before trimming:
I am worred about the airgap down at the cylinder base. Is this ok to run, or should I be looking for a newer style tin?
Your input is appreciated
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 01-30-2010, 02:18 PM
Forced Induction Junkie
WERK I's Avatar
.............................edit to save space.......................
My $0.02. My vote goes for the factory cut tin. My theory is the larger air gap closer to the cylinder head will allow more air to flow in that area where the greatest temperature is compared to the lower extremities of the cylinder.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 01-30-2010, 03:45 PM
930gt-40r's Avatar
I was in the same position last year when I converted to 3.4 fully finned cyls- I was going to squeeze the 3.3 tins on, but I sleep better at night since I bought the stock 3.2 fully finned tins. I got mine for $100 and had my friend sand blast them, then I painted them in high temp paint and now they are as new.
my 2 pennies
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 01-30-2010, 06:01 PM
I go with the 3.0/3.2 cooling tins as they dont have the reinforcements at the bottom to close the air flow.
Bruce
Old 01-30-2010, 06:17 PM
I'd either try to get the modified tin to resemble the 3.0/3.2 fully finned tin as closely as possible or just get a new set of air deflectors. Definitely, you don't want to run unmodified 3.3 half finned air deflector tin with that huge gap.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 01-31-2010, 02:50 PM
