mark '87 930's Avatar
another deck height question
I'm reassembling a 3.3 turbo motor. No machining was done at all.
I am rebuilding using the same used pistons and cylinders (the case was not split). When I disassembled the motor, I had only one 0.25mm copper base gasket.
I checked the deck height now as I have started the rebuild and can either get 1.15mm or 1.4mm with either one or two 0.25mm shims. The only change I am making to my engine is the SC cams which from my understanding have higher lift.
Thoughts?
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 02-04-2010, 10:18 AM
Mark,
Were your heads resurfaced (I hope they were)?
Use one base (.25mm) gasket for your 1.15mm deck height: you will not have any piston-to-valve clearance issues.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-04-2010, 10:56 AM
Yes, they were resurfaced.
1956 Chevy 3100
Old 02-04-2010, 11:37 AM
