911
Zenith carb parts advise
Hi there can anybody advise where I can locate this diaphram require X2 had a look through our hosts carb parts, looks like I may have to buy a whole kit .... any advise please
911
Oh there t T40 carbs
I simply bought diagfram material at the local store (thats simple elastic ruber) and cut the holes and general shape my self. Ended up with total cost of maybe 1usd and 15min time consumption
Regards, Kristijonas Valius '65 Porsche 912 #994 |
Try not, Do or Do not
That crap is in essence a decel device that is more about smog than performance.
You can remove it and plug the hole and it will perform for more consistently. Just a thought. To answer your question, I think we have some in stock. Royse (sp) used to carry kits that included those diaphragms.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
911
Hi there thanks for the information to confirm what holes are you advising to plug ??
Senior Advisor
you can just screw in the large philips (or straight) head screw on the body or remove the whole unit and plugging the hole at the top of the unit and caping off the vacuum ports.
08 Cayenne Turbo |
