rexav8r's Avatar
2.8 MFI questions...?
What does it take to build a 2.8 MFI motor ?
I hope that's not TOO open ended of a question...
What case is best suited ?
What P&Cs ?
What rods ?
What crank ?
What cams ?
Not a radically wild motor, something that has a realistic life span and can run on pump gas (even if it's premium pump gas)
I'd like it to bolt up to a 901 tranny and fit in a stock 1970 narrow body long hood.
I have a disassembled MFI 2.2S motor that can be used as a donor. Can the MFI pump be recalibrated for 2.8?
Can the 2.2S case be used for a 2.8?
I can get the part numbers if needed, but don't have them written down right now.
Thanks...
Richard W.
Red '70 E, 2.2
White (w/ Red & Blue), '82SC, "Frankenstein" -a bit tweeked
Old 02-27-2010, 09:49 AM
Richard,
2.8's can be built from two combinations of pistons and crankshafts: 92mmx70.4mm & 95mmx66mm.
The former is done on either an early 2.0 aluminum case or a mag case, perferably a 7R one. The latter combination is done using an early 3.0 Turbo case and 95mm P/C's with an early 66mm crank. Rods will depend on which combination you choose.
One can use either 92mm Mahle RSR P/C's (best for durability) or JE pistons in an aftermarket cylinder. The RSR pistons require twin-ignition as well as some modifications to get the CR into pump-gas range. Naturally, JE's can be ordered with any compression ratio you want.
Your MFI pump can be recalibrated to work.
JMHO, but I would not use your 2.2 mag case for this. An early aluminum case or a mag 7R are much better choices. The 3.0 Turbo case with 66mm crank is very durable.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-27-2010, 10:19 AM
3 restos WIP = psycho
kenikh's Avatar
One option Steve didn't mention: Get a 3 liter from an SC and buy some Nickie cylinders and matching 92mm pistons to get a 2.8 with a 9 bolt crank and heads that don't need a bunch of port and valve work. You do give up some displacement for posterity, so most just stick with the 3.0.
Don't bore a 2.2 case for 92mm P/Cs. All you'll do is end up crying when you break the engine and ruin your valuable S case.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-07-2010, 08:11 PM
Sports Purpose 911 Driver
mjshira's Avatar
what kind of power does an engine like make?
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 04-17-2010, 08:16 AM
OCD project capitan
BigD9146gt's Avatar
I've asked the same question over and over. I mostly hear a realistic ~250 crank hp for mine, but I can't wait to dyno my build: 3R/4R case, 2.7 crank, Mahle RSR P&C's, DC60's, mod MFI pump 2.7RS, ITG filters, 2.8 MFI injectors, twin plugged with Patrick Motorsports rotor setup, MSDS 6AL, heads ported 36mm Int/Exh, MFI stacks ported to match.
one day... soon! Who has an engine dyno near SLO or South Bay Area? Cost?
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 04-17-2010, 08:56 AM
There are many variables here: cams, compression, heads (a biggie), exhaust system, and even the MFI pump, all affect what kind of power you get.
A 2.8 can make between 240BHP to 275BHP with streetable camshafts.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 04-17-2010, 10:30 AM
Try not, Do or Do not
Henry Schmidt's Avatar
There is a least one another option that has been over looked.
You can build a 2.8 using a 3.0 and 3.2 core and installing the Supertec 66 mm SuperCrank.
Benefits include late style oil, use of GT3 Titanium Pankl rods, good parts availability and stable case platform.
You also get the benefit of a nine bolt crank. If you want to rev your project, 2.4/2.7 crank are woefully inadequate.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-17-2010, 10:45 AM
OCD project capitan
BigD9146gt's Avatar
Henry... that crank is SOOOOOOOOOO HOT! TOOO SEXY!!! Want to touch it! Oh well, next motor...
Don Welch
Old 04-18-2010, 11:11 PM
