Rick
Thanks in advance for the help. It seems that I am always asking questions. Hopefully I will get to the point in the knowledge curve that I can start answering questions for others.
The pictures of the detailed engines were great, so i decided to remove the alternator from the blower housing in order to powder coat the fan and the housing. BUT, the alternator refuses to come out, even after I showed it the pictures of an alternator without the blower housing in the Bently book and the Haynes book. Is this a case of needing a bigger hammer (again)? removing the long bolts didn't seem to make a difference, and I cannot find any other fasterner. Is this a pressure fit? Just put PB blaster on it and tap with a hammer? engine is 2.2 l 911E 1970. Rick
Rick 1970 911 E purchased in Stuttgart in 1973 |
Not the hammer. I am also curious about this as I used a hammer and a punch to get mine out and broke a few ribs on the back of the alternator (I am replacing anyway).
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
beancounter
Use the "drop method"
Strategically place some pieces of scrap wood about the same distance apart as the diameter of the fan housing. Drop the fan housing and alternator assembly face down from a few feet high onto the scrap wood. Alternator comes out easy this way. Put down a towel of something so it doesn't hit your concrete floor or driveway.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
The drop method works for me but it took me 27 years before I heard about it and that cost several alternators along the way.
Bruce |
Black and Blue
ive used the drop method with success
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Rick
It was AMAZING! three gentle drops from about four inches above the boards, and the alternator slide free.
Thanks. Rick
Thanks should go to John Walker who taught me this method!
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
THANKS again for the drop method...Worked like a charm....Cheers
Scott 1979 930 - Black on Black and in the woods "My third child that will cost more in the long run" :shock: Last edited by vascott01; 08-05-2015 at 04:10 PM.. |
