574 loctite removal, Mec & brush
I know it is recommended to use Mec and a wire brush to remove loctite 574, in this case from the cam towers. Any concerns with the wire brush upsetting the surface of the tower? The wire brush I have isn't real stiff.
Senior Advisor
no big deal but it's MEK (methel ethel ketone) mmmmmmm good stuff.
08 Cayenne Turbo |
UnRegistered User
Try Locktite Chisel.
It is nasty stuff too, but it works.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Try not, Do or Do not
We use MEK, just be very careful with exposure. Don't get it on your skin and limit the amount you breath. That Shiiiit is nasty!!!!!
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I'll give it a go, just have a little left to get off. Yep MEC is hairy.
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
GAFB
Ye gads. How's that working out for you 40 years later? You ok??
Several BMWs |
The funny thing was that in 1970-71 I was handed the OSHA manual and instructed to make sure the building and equipment would pass. IIRC nothing mentioned about the chemicals other than to secure them from tipping over and spilling. Some regulation is a good thing!
