SWB Enthusiast
SC Oil Pump into 5R/7R case
I am sure that this has been covered before but I want to fit an SC pump into a 2.7 mag case.
Does anyone know which parts I will need in addition to the pump?
I have tried to search previous threads but haven't found much.
Old 05-15-2010, 01:41 AM
When using an SC pump you should also upgrade to the venturi sump screen.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 05-15-2010, 02:30 AM
SWB Enthusiast
Oil Pumps
I also read a thread that talks about 'short' shaft pumps.
It says that 964 pumps are magnesium and not good, any ideas why? Is it just expansion problems or are there other issues?
Old 05-15-2010, 02:36 AM
The SC pump can use your existing long shaft. The 964 and later pumps use the shorter shaft.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 05-15-2010, 08:52 AM
You will have to do the "oil bypass" modification if you have an early case. I'm not sure what the cutoff year is but I think it's around 1975.
-Andy
Old 05-15-2010, 03:43 PM
