3.0L stock rods & bolts
Hello,
Because we are in the final stages of fine tuning my warmed 3.0L SC engine with 40 Webers, GE 60 cam and JE 95mm Pistons I fear the stock rod bolts on the stock rods might not hold to the estimated max 7,1-7,2k RPMs where we plan to set the rev limiter to.
Would you think that the stock rod bolts will probably cause a problem here and we definitely should change them to ARPs?
Thanks for your input,
Christian
Old 05-09-2010, 04:57 AM
3.0 rods
For what you describe the stock rods will work well with ARP/race bolts, providing they are properly resized,magnafluxed,rebushed etc. and most importantly the rod bearing clearance is proper and not too tight. I would also recommend using the GT3RSR bearings instead of the street OEM or glyco bearings as the quality of the street bearings has not been very good for severe duty.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 05-09-2010, 05:18 AM
Thanks, Mike.
So you would recommend no to use stock rod bolts for my application?
The long block is finished and actually in the car right now, so changing the rod bolts to ARP would induce lots of work here...
Old 05-09-2010, 07:18 AM
BURN-BROS's Avatar
The stock rod bolts will work for the rpm range you have stated. However I would still upgrade as it is relatively cheap insurance.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 05-09-2010, 07:21 AM
I think Mike & Aaron offer solid gold advice,.....
Cheaper and more convenient to do this now rather than deal with any consequences from extended high RPM use.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-09-2010, 05:07 PM
3 restos WIP = psycho
kenikh's Avatar
WTF??? I called my Porsche dealer and they told me all GT3 rod bearings are the same part number as the SC. Please explain, because I just DFL coated a set of Glycos I was told were the same as GT3.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-09-2010, 07:58 PM
a.k.a. G-man
Geronimo '74's Avatar
3litre rodbolts are 10mm instead of 9mm for the 3.2, so you should be fine.
9mm bolts are marginal in strength in the higher RPM range, the ones you have are stronger.
It never hurts to upgrade to ARP though.
Old 05-09-2010, 09:21 PM
Hi Kenik,
The person you spoke with at your dealer is quite mistaken,....
GT-3 rod bearings carry a 996 prefix and SC ones have a 930 one; they are totally different parts.
These good bearings are not available through the aftermarket and are dealer items, only. Naturally, they come in Porsche boxes, not the red & black Glyco ones.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 05-09-2010, 11:25 PM
Lots of good advice here, thank you!
So the GT3 rod bearings are available through Porsche dealers? Could anybody state the spare part #?
Old 05-10-2010, 01:09 AM
a.k.a. G-man
according to PET 6
996 103 121 94 (for the GT3 2004 and onwards.)
Old 05-10-2010, 01:15 AM
RSR brgs.
That is the part # for the RSR bearing, It is treated as a motorsport part in the US and the dealers can't get them. And PMNA sure won't sell them to you unless it is packed in your freshly rebuilt race engine
Old 05-10-2010, 04:21 AM
RSR brgs
Kenik, the real problem with coatings on those bearings is the build up per shell can be .0004 in. and that reduces the already too tight oil clearances in most cases unless you coat,measure, and then have the crank ground to size.
Mike Bruns
Old 05-10-2010, 04:24 AM
UnRegistered User
billybek's Avatar
From the last few months of reading this forum, it would seem that the dealer supplied bearings go through a more rigorous selection/inspection process than the aftermarket bearings. Sounds like you are ok. (not GT-3 bearings though).
Bill K.
Old 05-10-2010, 04:26 AM
kenikh's Avatar
Can this be right?
Pelican Parts - Product Information: 996-103-121-94-M100
Pelican sells them for $25/set. Doesn't sound right.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-10-2010, 10:06 AM
kenikh's Avatar
Looked again. I did order the right part number:
996-103-121-94-M100
But they came in a red and white box. Odd.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-10-2010, 10:08 AM
bearings
Its probably 25.00 per shell (or 50.00 per rod) that is the right part # post a pic when you recieve them
Mike Bruns
Old 05-10-2010, 10:25 AM
kenikh's Avatar
Will do.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-10-2010, 10:32 AM
996-103-121-94-M100
Did you get them from the Dealer?
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 05-10-2010, 11:37 AM
kenikh's Avatar
No - a friend who has a local shop got them for me. I am getting the parts back in a few days...I'll look more closely when in hand.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 05-10-2010, 12:06 PM
FWIW,..Dealer-sourced bearings are far preferable to aftermarket ones and thats all we use in these particular engines.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 05-10-2010, 04:18 PM
