Daviboy's Avatar
Gratuitous Clean Case Shot
Not really re-build related well kind of.... just spent last 4 hours cleaning up internals of the cases it is so satisfying to see something thats 28 years old looking so good...
Davy
82 911 SC Targa Sold
12 Audi A5 Sportback 3.0 TDI Quattro
03 996 C4S
Old 05-28-2010, 05:40 AM
al lkosmal's Avatar
Looking very nice Davy. I never get tired of seeing how nicely these clean up.
Regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 05-28-2010, 08:22 AM
a.k.a. G-man
Geronimo '74's Avatar
Great job Davy!
Ready to assemble so it seems.
The case was repairable then?
Old 05-28-2010, 09:55 AM
Daviboy's Avatar
Thanks guys especially Geronimo sorry about before. Yes the case came back looking great all within spec and they made a great job re-sleeving #2.
Before
After
Davy
03 996 C4S
Old 05-28-2010, 12:52 PM
Nice job Davy, you can eat off that thing!
My case was just like your's a few months ago, not as clean, but pretty close.
Here's were I'm at now, minus the fuel injection, recently installed.
Leakproof.
Restoring/Rebuilding Yellow Canary '79 911SC
Suspected track car
Old 05-28-2010, 03:27 PM
Daviboy's Avatar
Looking good Leakproof. I will be a while before I get to that stage. Saving for parts and shipping time means I will be off the road until about September. I am however going to keep a blog of progress
Davy
03 996 C4S
Old 05-29-2010, 01:54 AM
a.k.a. G-man
Originally Posted by Daviboy View Post
Before
After
Wow That turned out nicely!! Glad to see the case could be saved.
What did you use to get the inside this clean?? Just brake cleaner and a cloth??
Somehow I just don't see me getting my case as spotless as yours.
(no need to apologize, I overreacted too. I guess we both needed a deep breath and a 10 second time out before hitting the keyboard. )
Old 05-31-2010, 10:52 AM
Daviboy's Avatar
Thanks Geronimo yes the machine shop made a great job on that. As far as cleaning goes after soaking with a water based engine cleaner I hit it with the steam cleaner set as high as it would go. I then hit the bearing webs with some super fine polish and the dremel with some cotton cleaning wheels. 1800 grit paper on the case seal areas. After that about 4 hours with the carb cleaner and lint free cloths. All in all about 6-8 hours cleaning the internals, took a cleaning kit for a 12 gauge and hit all the internal oil lines where the case through bolts are located. Blew through every oil passage I could find and the piston squirters.
I may be a bit anal about cleaning but after years of running and maintaining hydraulic downhole valves in the oil and gas industry I got to know that cleaning and prep work are more than half the battle. Never had a valve fail on me even at 18,000ft and 6,000 psi at 230 deg F.
Davy
03 996 C4S
Old 05-31-2010, 11:54 AM
