HKZ Bob's Avatar
Usage of upper O-ring of chain tensioner
Hi
I have two tensioners disassembled where the O-ring no 9 was missing.
Outer diameter 13mm inner 8mm
Where does it this no 9 o-ring belongs to and what is the purpose.
I assume on the piston 7 upper groove but I want to be sure.
Please add photo, would be great thank you.
Thank you
bob
Old 06-07-2010, 08:40 AM
IIRC it is inside part #7. There should be a groove inside for this o-ring.
It was really hard to get out until I discovered the perfect tool for picking
it out - a corkscrew.
andy
Old 06-07-2010, 05:09 PM
HKZ Bob's Avatar
andy
Hi
What is this o-ring 9 good for?
BR
Bob
Old 06-08-2010, 03:58 AM
I guess it stops oil from escaping up the stem. Part
7 seals at both its inner and outer surface for some
good reason.
andy
Old 06-08-2010, 04:51 PM
the o-ringed disc keeps air out of the lower section. air entry is what causes tensioner collapse. air compresses, liquids don't, remember?
206 637 4071
Old 06-13-2010, 08:53 AM
HKZ Bob's Avatar
good reason.
andy
Part no 7 has two o-ring grooves
The big o-ring 8 seals against the liner 19. but the small oring 8x13x2.5 Viton is been inserted on the upper grrove on part 7.
But what it is purpose?
Is is for centering the the disk 5?
BR
bob
Old 06-13-2010, 02:19 PM
Tags
tensioners
