OldTee's Avatar
Fan belt too tight?
Old Tee
all 911s sold
Old 01-21-2011, 06:47 AM
He ran it with no belt and same sound. Good luck !
Old 04-05-2011, 09:53 AM
tyro's Avatar
Originally Posted by 4sd911 View Post
I've removed the pressure feed tensioners and installed turbo style tensioners
I'm curious about the turbo style tensioner? Spring type? Have a part number handy?
Thanks,
Jess
1980 911SC Euro
1993 Audi CSQ
Old 04-07-2011, 04:00 PM
These Pelican Parts - Product Information: 930-105-053-00-M260 the last of the contained oil / spring type, some call them "turbo" because of the 930 part no.
Old 04-07-2011, 06:08 PM
El_Mecanico's Avatar
Did you ever figure out the problem?
1986 Porsche Carrera
1997 Porsche Boxster (Sold) :0
1995 911 Cabriolet (Sold)
1971 Porsche Targa 911E (Sold)
Old 02-26-2012, 04:43 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I did. turns out all the head studs on the right side were lose. It's a head scratcher as to why but every head bolton the right was lose a 1/4 turn.
Torqued them all back up and runs like a champ again.
Chris
73 911 E
Old 02-26-2012, 05:42 PM
Switching to the tensioners back to the "Turbo" type got rid of the "noise". I don't know if it was really a problem in the first place, or if the pressure fed tensioner's were bad or the different chains were just noisy. I suspect the pressure fed tensioner's apply more tension to the chains than the Turbo type. I do get a little chain noise at cold start up for about 30 seconds until the tensioner's even out, had that same issue with the pressure fed type before the rebuild.
Old 02-26-2012, 08:34 PM
cmcfaul's Avatar
sorry, just realized I replied to the wrong thread.
Old 05-20-2013, 01:47 PM
