Usage of upper O-ring of chain tensioner
Hi
I have two tensioners disassembled where the O-ring no 9 was missing. Outer diameter 13mm inner 8mm Where does it this no 9 o-ring belongs to and what is the purpose. I assume on the piston 7 upper groove but I want to be sure. Please add photo, would be great thank you. ![]() Thank you bob |
IIRC it is inside part #7. There should be a groove inside for this o-ring.
It was really hard to get out until I discovered the perfect tool for picking it out - a corkscrew. andy |
I guess it stops oil from escaping up the stem. Part
7 seals at both its inner and outer surface for some good reason. andy |
the o-ringed disc keeps air out of the lower section. air entry is what causes tensioner collapse. air compresses, liquids don't, remember?
The big o-ring 8 seals against the liner 19. but the small oring 8x13x2.5 Viton is been inserted on the upper grrove on part 7. But what it is purpose? Is is for centering the the disk 5? BR bob |
