How to remove flywheel bolts?
Hi all,
please advise if the tool to remove the flywheel bolts has to come from Porsche or is it a standard 12 point torque drive socket that will do it? and where would i purchase the correct tool in LA. cheers |
Standard 12 point and its available auto stores.\
Bruce |
Super Moderator
It's best do do this with the engine NOT on the stand. (rather on a jack or table) THe bolts heads are shallow and often locktited in. I hit them with a torch to help release any locktite and use an impact so I can push the tool into the bolt-head.
