Mo money = mo parts
Drain Plug Analysis
I rebuilt the top end of my motor this past winter. I changed the oil after about 20 minutes, then 20 miles, then changed it again at 100 miles and now changed it again at 500 miles. I replaced the drain plug in my case with a magnetic plug. It had a non-magnetic plug previously, so I had no baseline for metal on the plug. The magnetic plug on the tank never had and does not currently have any visible metal.
Here is a shot of the drain plug. Again, last oil change was 100 miles, this one about 500 miles. I have been running Brad Penn 30 WT Break-In, switching now to BP 20w/50. Does the amount of metal look normal? Thanks.
Top End & Reseal
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 07-09-2010, 06:48 PM
abit off center
cgarr's Avatar
It looks ok as long as it just fuzz, run it thru your fingers.
______________________
Craig
G2Performance
Old 07-09-2010, 06:57 PM
Mo money = mo parts
Thanks Craig - I think I fall into the "fuzz" categories, because there didn't seem to be any substance to it. Like it melted as I was wiping my finger across the magnet.
Greg
Old 07-09-2010, 07:16 PM
