rluciano's Avatar
Injection Timing Question and Ignition timing too
I'm getting pretty deeply into tuning my newly rebuilt engine.
First what is it:
1982 SC block with 100mm Nickies, JE Pistons (10.05:1 compression ratio as cc'd)
Heads: '82 SC heads twin plugged Supertec valve springs, Ti retainers, 36 mm ventiport inserts, new valves and guides.
Stock rods with ARP rod bolts
Hargett ITBs with 46mm butterflies, Ford Motorsport 39lb/hr injectors, Toyota Tundra COPs, SSIs and a Monty 2 in 1 out muffler.
Cams- DC 60 with 106 lobe centers.
EFI- MoTeC M800
Now my 2 questions:
1. The MoTeC allows me to specify either the time fuel injection begins or ends in degrees BTDC. I bought the MoTeC used and the program that was in it had injection ending 320 degrees BTDC. That seems awfully early to me. I moved to 270 degrees at idle to 200 at 7500 rpm redline. I think I could keep going closer to TDC: maybe 250 at idle to 160 at redline. What do you think?
2. I had used Jamie Novak and brads911sc timing comments on their build threads, but both of them are using distributors. I have more flexibility with electronic ignition. I found these graphs on Steve Wong's website.
My engine feels like it wants a lot more advance than I am currently running. I am running something that looked like the WOT curve from Steve, but with Jamie and Brad where they are I hesitate to go 40 degrees of advance. I'm using MAP as load I don't know what load is on the graphs on Steve's website.
Is the only thing to do spend time on the dyno? I tried going to use much as 30 degrees on the road the other day, it is more powerful, but the lambda went from 0.90 to 1.08; so I added fuel, but I worry how much timing is safe with twin plugs and 93 octane fuel and 10.05:1 compression and my DC 60-106 cam?
Thanks in advance for any help,
Richard
Original owner 1986 944
1987 951 968 wing from CPR, Deutsche Nine headlights, KW Variant 3s, Lindsey Stage 2 intercooler, Big Reds
2003 Ruf 3600S S-Car-Go equal length headers, otherwise almost stock
72 911T w/ SC 3.3SS engine MoTeC Hargett ITBs
Old 07-17-2010, 02:04 PM
rsscotty's Avatar
PM me your email address and I will get you some info.
Old 07-17-2010, 05:26 PM
Navin Johnson
TimT's Avatar
How is the ignition and injection configured?
Batch fire/waste spark?
Sequential/sequential?
It makes a difference.. If batch fired injection end angle doesn't really matter..
Need to know more about fuel and ignition set up.
Being able to sit and drive against a dyno for few hours is time well spent
'69 911 GT-5
'75 914 GT-3
and others
Old 07-17-2010, 07:02 PM
rluciano's Avatar
Injection and Ignition are both fully sequential.
Adjustable FPR from Marren set to 3 bar.
Toyota Tundra (denso) COPs two per cylinder
What else do you want to know?
Old 07-17-2010, 07:16 PM
