2.7 rebuild Oil PSI
Hello,
Just started engine after complete rebuild, what oil PSI and Temp. should I get? Thanks!! |
Max Sluiter
between 10 psi and 1 Bar per 1000 rpm, at operating temperature.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
2.7 should probably peg up on 20/50 cold then come down as it warms to the 10 to15#/1000
Bruce |
Don't forget that oil viscosity and bearing clearances play a big role in cold & hot running pressures.
You really want to keep a 2.7 under 210 degree F oil temps for durability as well as power.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
air+fuel+spark
Pressure/Temp (Normal) 2.7L= 10~15psi @ 1000rpm (startup= 20~50psi) 210°F
Are the above numbers for a stock 2.7 with a 5 or 11 blade fan? Does the addition more oil cooling to the system (front mounted ...to be determined) change the normal temp/pressure numbers? MorganHarry congrats on the new motor. I am just starting a 2.7 rebuild/rodded motor. (Project kickoff forthcoming). I am starting to gather data...apparently bassakwards b/c at this point starting the motor is way into the horizon
bryan 1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle R Gruppe #653 |
Thread Tools | |
Rate This Thread | |
