GBStu's Avatar
Gents,
I have my engine back together (new #3 piston and all new rings, I have about 200 mls on the engine)
I've adjusted the warm pressure to get the desired AFR, the graph below shows a couple of WOT runs I took tonight. What do you think about the graph below...specifically the AFR from 3000 rpm to 4500 rpm.
Thanks, Stu
Old 09-20-2010, 05:18 PM
Were those runs done at WOT?
If so, looks too lean to me from 3K to 6K.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-20-2010, 05:35 PM
GBStu's Avatar
They were WOT runs in 2nd gear.
Any idea why the AFR drops at 5600-6500 so much?? I have CIS injection.
I'll drop the WUR control pressure a couple of psi and re-run tomorrow.
Thx, stu
Old 09-20-2010, 05:43 PM
Thx, stu
This is pretty typical of CIS and illustrates one of the difficulties with modifying these things.
Although long unavailable, an ROW Carrera 3.0 FD & WUR would really help. You may be able to find these components with some dilgent and persistent searchs both in Europe as well as here. At the very least, an ROW early SC FD & WUR will also help.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-20-2010, 10:20 PM
GBStu's Avatar
Is the fundamental issue the control pressure regulator (WUR) will not flow sufficient fuel, thus, at the higher RPM's (>5700rpm) the outlet pressure drops and the mixture richens?
Stu
Old 09-21-2010, 04:36 AM
Have you tried to richen the fuel distributor itself by adjusting the mixture screw?
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 09-21-2010, 05:46 AM
Grand Am/IMSA Data Guy
Porsche84's Avatar
I had very similar issues 5 or 6 years ago. The bad news is that I ruined two motors before I found the problem. The problem was that I inadvertently closed off the gas tank vent when removing some smog stuff (track car not street in case the Feds are reading). My engine shattered the top ring on brand new euro Mahle pistos and new cylinders. You need to verify that you have a good tank vent. Check to see if the tank has collapsed, that is the first clue.
Good luck
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 09-21-2010, 06:35 AM
Stu
The fundamental problems are that in most cases, the FD doesn't flow a sufficient volume of fuel for modified engines and the control pressure doesn't go low enough to get the most from the FD.
In some cases, we shim the system pressure (at the FD) to the top limit and use an electronically-controlled WUR to get a better handle on control pressures from cold to hot.
The stock WUR's are somewhat frustrating since its difficult to get proper AFR's without overfueling near and at idle. Its akin to squeezing balloons.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-21-2010, 10:14 AM
GBStu's Avatar
Adjusted the warm pressure to 33psi, see WOT plots below. From what I've read, this seems about as good as I can expect.
What's interesting, the WUR warm pressure spec for a stock 79 is 39-43psi (no vacuum).
Thanks for your help, stu
PS, will be with ARPCA at Mid Ohio this weekend
Old 09-21-2010, 05:45 PM
Although a tad rich for making max power, that red plot ensures your engine will live provided your ignition timing isn't too aggressive for the fuel you use.
A digital WUR would allow you to fine tune that AFR curve to get best performance without compromising reliability.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-21-2010, 10:18 PM
Send a message via Skype™ to KNIGHTRACE
set timing right, and check deck on al 6 cyls and it will answer itself.
Old 09-22-2010, 12:21 AM
