dweymer's Avatar
crank specs-too large?
I took a 3.0 crank to the machine shop for polishing and mic. They told me the measurements were as follows, and commented about it being larger than spec.
Mains:
2.3619
2.3619
2.3619
2.3621
2.3619
2.3621
2.3621
Rods:
2.0861
2.0862
2.0861
2.0862
2.0861
2.0862
According to the book I have, yep they are large by about .0001 & .0003. How is that possible, and how much will that affect the bearing clearance? I suppose the question it boils down to is: will it cause problems to run as is?
D
Donnie
Currently Porsche-less.....
Old 09-01-2010, 08:27 PM
haycait911's Avatar
operator error/variances in measuring tools. looks like what you have is a damn near new-spec crank. you're talking about 1 to 3 TEN-THOUSANDTHS of an inch. nothing. be happy and run it. maybe someone with more experience will chime in here. FWIW most specs are to the thousandth of an inch, accuracy can get dicey past that.
Old 09-01-2010, 10:06 PM
SWB Enthusiast
Micrometers
Understanding resolution and accuracy of measuring instruments is always quite tricky.
A typical modern micrometer will have a graduated scale with a resolution of 0.0001" and in the case of a digital micrometer this could even be 0.00001"
This doesn't mean that they are accurate to this level.
A typical accuracy (better to think of this as uncertainty) is 0.0002" and this assumes a good quality micrometer which has been recently calibrated, etc, etc.
As the tolerance in the bearing clearance on a 2.4" main is significantly greater than a tenth of a thou I wouldn't worry.
Old 09-02-2010, 01:10 AM
abit off center
cgarr's Avatar
How hot is it in their shop?
______________________
Craig
G2Performance
Old 09-02-2010, 02:39 AM
dweymer's Avatar
Thanks guys, I do know it was a low mileage engine.
Craig, hey man, glad to see you are still around; it is probably about 75 in their shop.
Donnie
Old 09-02-2010, 06:07 AM
Chain fence eating turbo
All post spot on. Coming from the aerospace industry, I wouldn't put a lot of faith in machine shops' measuring devices. Do they calibrate regularly? Maybe. Maybe not.
Who's to say a guy had or had not dropped the mic on the ground or table. This is all it takes to knock them out of calibration.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 09-02-2010, 06:49 AM
304065's Avatar
I calibrate my micrometer with a standard before EVERY measuring session. It's easy even for a monkey like me. Since my environment is not maintained at an ISO 20C temperature, there's always some variability. But what matters is repeatability of measurements on the same day.
I don't use decimal inch although many people do. 0.0001" is 0.0025mm or 2.5 microns, the factory measured to microns using a Mahr Millimess, probably calibrated with a stack of gage blocks.
So you do your measurements in microns and then fire up an aircooled engine with the barrels attached to a two-piece engine case with long bolts and all the tolerances go to hell, the cylinders look like bananas at operating temperature and the engine grows 1/8" wider due to thermal expansion!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-02-2010, 07:16 AM
I would rather be driving
jpnovak's Avatar
Donnie,
I had a 3.0 with ~80K miles that had the same numbers for the crank journals. 2-3 were above spec and the others were right on the highside of the diameter spec.
It is likely a combination of a VERY good crank and slight measurement error through temperature or calibration variations.
Old 09-02-2010, 07:17 AM
jpnovak's Avatar
John, Great way of putting it all in perspective!
Old 09-02-2010, 07:18 AM
abit off center
cgarr's Avatar
Just for fun years ago I wanted to see how big the mains would grow on a mag r7 case. After heating it up to around 190 the mains were out of spec by .002
The old 912 engines push rods would grow .013 in length after hot, luckily everything else enlarged too!
So it is true, cold shrinks, heat expands!
Craig
G2Performance
Old 09-02-2010, 08:10 AM
Here is a typical 3.0 crank inspection report (sizes in mm).
Your data is well within OEM specs
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 09-02-2010, 05:18 PM
abit off center
cgarr's Avatar
I just check the mains on my 2.7 crank, at 68 degrees it was 56.979 at 98 degrees is measured 57.007 so I guess when you all ask about a crank you want to purchase you better know at what temp it is was checked.
Craig
G2Performance
Old 09-02-2010, 05:55 PM
Craig
Your measurements are pretty close for a 30 deg temp change.
The thermal coefficient of expansion for carbon steel is 0.000011. Raising the temperature at 68 deg by 30 deg results in a 0.02 mm change on a 60 mm linear dimension.
Aluminum pistons are even more critical as the thermal expansion coefficient is twice as big at 0.000023. An 80 mm piston increases in diameter by 0.06 mm for a 30 deg temperature change.
In the aerospace world, we require that all dimensional inspection areas maintain 68 deg +/- 1 deg.
I make all my Porsche inspections in my temperature controlled basement :-)
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 09-02-2010, 06:28 PM
304065's Avatar
Guys, Tom is being characteristically modest. I bought a crank from him and had the opportunity to visit his basement-- on the surface it just looks like racks and racks of cool Porsche parts, but upon closer inspection. . . he's got it set up for dimensional metrology. . . just like an engineer. . .
'81 R65
Old 09-03-2010, 06:29 AM
John
Since your imagination is running wild...and I love to exaggerate....I need more space to store the inventory of 911 parts I can't stop myself from buying.
I am looking at anunderground storage area below my concrete slab to create additional storage space. It would be a tribute to Gary Fairbanks, who introduced me to the wonders of dimly lit sub-terrainian caverns filled with magnesium castings.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 09-03-2010, 05:05 PM
