MJP MJP is offline
Your engine looks great! What fuel pump did you decide on, and where did you mount it? I don't see a fuel return line off the fuel manifold, do you have a regulator with a return line mounted somewhere?
Old 07-27-2011, 03:01 PM
Joost73's Avatar
Nice to see others are doing the same thing, are you leaving the 912 motor stuts in?
1988 911 3.2 Carrera
@joost_hermes
Old 06-28-2014, 03:44 PM
My friends call me Phish
I am.
That way I can easily convert it back to a 912, just in case I want to sell it as an original 912.
It's a 3 gauge and I am not planning on adding the other gauges too. I will most likely build a gauge set up that I can fit into the radio cut out.
Old 06-29-2014, 11:09 AM
