My friends call me Phish
Dizzy Rebuild
Can someone explain what recurving a distributor means and does it have to be done on a CIS system to Carbs and is it something I can do myself?
Thanks.
Old 10-02-2010, 05:46 PM
In a nutshell, recurving a distributor means modifying the advance weights & springs to allow more ignition advance at a lower RPM for better throttle response and engine acceleration. The limitations are mainly octane and compression ratio.
You need a distributor machine to precisely measure advance at all RPM to achieve the desired result. Further, you need a selection of springs and weights to fine-tune the unit to get the values you want.
Does this help??
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-02-2010, 08:55 PM
Arrow
Re-curving a distributor means changing the advance curve and limit, to maximize performance based upon your engine configuration, and driving preference.
What distributor do you have?
Engine?
Mods?
Track, street, combo?
Pictures?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 10-02-2010, 08:57 PM
I am attempting to change a 2.7 CIS into a 2.7 carburetor. The build is going to be JE Pistons 9.5 CR, with E cams and 40 webers. The car will be street driven and i don't believe there is any special mods.
Thanks a bunch to the both of ya
Old 10-03-2010, 01:07 AM
I would make sure your distributor doesn't have worn bushings or excessive end play when you recurve it. Most high-mileage ones need to be rebuilt.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-03-2010, 09:36 AM
.....the sound, I believe is similiar to, cha ching. Probably around 500 + for rebuild and recurve. You probably will not find anyone who is going to just recurve it, in a high milage condition.
Old 10-03-2010, 10:59 PM
Thats absolutely true,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-04-2010, 01:26 AM
Constitutional Liberal
Turbo_pro's Avatar
Contact Aaron (Burn_bros) he is as good as they get at this kind of distributor service.
Rennwerks Inc.
Aaron Burnham
Camarillo, CA.
805-240-6931
aaronburnham@hotmail.com
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 10-04-2010, 06:46 AM
